Monster MotorsportChris Nott
Results 1 to 18 of 18
    QuattroBro
    23
    Arrow Dump Valve Question 1.8TQS
    hi guys,
    ok can i first off start by saying im NOT a chav!!! lol however i still would like sto fit a dump valve to my car.......not a ridiculously loud one that makes a noise louder than the engine, just one you can hear in a subtle way.........
    preferably i would like one where the noise can be turned on and off at will but im sure thats not possible.......
    either way i know fitting a cone air filter imporves the engine noise and i would like a dump valve to go with it......somthing cheap if possible.....
    any one fill me in on what kind to get and generally what a dump valve does if anything?
    cheers guys
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,078
    Fitting the cone filter should make the factory recirc valve more audible. Be aware that oiled filters can cause fouling of the MAF and you may need to clean it a few times.
    I run a K&N cone with a Forge 007 re-circulating dumpvalve an it's quite audible but not OTT
    Life begins at 140mph
    www.passionford.com
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    I looked to put a cone filter on mine, but with all the stuff hung on the airbox it looked too much like hard work. But with the new turbo going on soon ill look to relocate stuff...
    Drizz Developments - Audi A4 Avant Quattro Sport
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    The biggest issue with using a dump valve on a MAF equipped engine like the AEB is that because the ECU uses the MAF readings to calculate the fuelling, when you dump the air it acts like a massive air leak, and you end up with a large rich spike immediately after the dump causing all sorts of running issues, as the ECU doesnt realise the air's gone, and fuels for it anyway.
    I would fit the cone filter first if you really want the noise, and see how that goes.
    Personally, both mods deserve to go in the bin where they belong. Cone filters DO NOT filter properly, which is why they are coated in oil to attempt to do what the filter element is not. They also dont actually improve power. If you want an engine note then change the exhaust, as at least that has no unwanted side effects.
    You might get a better engine note by modifying the airbox, opening up the air inlets by drilling extra holes in the lower section and removing the "snorkel" will give you more of an engine note. Best of all its free.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,078
    I'm not sure I would entirely agree. A cone filter correctly used can give an improvement in power from the testing I have seen. My own car recorded slightly better results with the cone than without. At best I would say it's a bit of a grey area.
    Agree with you on the DV thing though
    www.passionford.com
    Mar 2009
    Scotland
    218
    Evening all. I've got a Forge Splitter DV on my TQS. I've seen no bad results from having it on. It has many different variables in how much 'dump' you release. I think mine is about a quarter turn and is deffinately audible but not scooby like. I'm no chav either but have always liked the noise made by a dumping turbo
    132
    Paper filters do filter more than oiled cotton gauze filters.
    "Stick a V8 in it!"
    15,324
    Quote Originally Posted by Oranoco View Post
    It entirely depends how restrictive the stock intake is.
    Various mags over the years have run back to back dyno tests on cars with and without "induction kits" and often there is no difference, or the difference is so small you cant draw any real conclusions (gaining 3hp on an engine developing 170hp for instance is such a small change it cant scientifically be attributed solely to the filter, and simply comes down to experimental error).
    Some cars WILL show an improvement, one that comes to mind is the Fiesta ST with the 2.0 Mazda engine. But that happens for a reason, the engine makes 170hp in the MX5 and 150hp in the ST, and most of that difference comes down to the restrictive intake system ford fitted on the Fez. Fit a cone filter/induction kit and you'll see 160-165 all day long. That doesnt mean the filter itself is any better, its just the intake setup as a whole is much better.
    By all means a paper filter might cost you a horsepower or two. But i'd rather have 148hp and properly filtered air, than 150hp and half the sahara being drawn thru the engine!
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,078
    Indeed, like I said it's a bit of a grey area and personal opinion differs. I can't say I'm convinced either way.
    www.passionford.com
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    I ran a DV for 2.5 years with not one issue to and to the mix.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Mine was fine until the turbo packed up!
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    i used to run a K&N cone filter and my audi used to sound like this!
    Now to many mods to list! Lots of power, torque and Leather!
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Guessing you had no DV at all then?
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    yep.. i had a oem Audi TT recirc. Let byzan be my witness! lol
    Mar 2009
    Scotland
    218
    I thought you only got chatter when there was no DV? Something to do with compressor stall or the like? Then again I may be wrong
    Oct 2009
    Nottingham
    17
    I want mine to sound like that!! So that was with a TT DV and K&N Induction kit?
    Dan
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,078
    The spring was too strong in the DV so it wasn't opening. The way these cars operate with a MAF sensor means the y don't like chatter, the turbo's are also signifcantly less robust than say a Garret T3. Shame as I loved the noise my old Fiesta made
    http://www.youtube.com/watch?v=ts6_ZCjtLUQ
    www.passionford.com
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Good lord, small world. I clipped youre you tube video ages ago so my mobile phone msg alert was youre chatter LOL
