JMB RetrofitsBadger5
Results 1 to 10 of 10
    Nez
    Dec 2008
    London
    595
    Few works done on the Car
    After rolling road day which you some of you guys know that the car put only 319 BHP :cry: I thought it was time to take the car for a health check and pressure test it as I knew there was something wrong with car and also I change the rear springs as the both was breaking :P and I finally fitted my Hose pipes too and also add up the picture of the rs4 intercoolers when I fitted.
    Ok here we go here is some pictures:
    First here is few picture of the car when we fitted the rear springs and by the way the rear springs were so easy to change without any problems :D
    Here is the breaking spring:
    Here is few picture of the Rs4 intercoolers:
    We started at 09:30am ad we started to take out first the front bumper, Head light and the S4 intercoolers.
    Here is the difference both the standard S4 intercooler and the RS4 intercooler:
    Final picture after we fitted the RS4 intercoolers:
    Here is the Hose pipes after fitting all fitting fine only the I only had problem with Y pipe fitment as it was different then standard pipe:
    After fitting the intercoolers and the Hose Pipes time was for a pressure test and health check and today I took the car to Romford to turbo specialised and after pressure tested we found out a big leaking on the driver side top pipe it was so big leaking that after 1 bare we could hear the fusshhh sound.
    The reason for the leaking was because of the RS4 intercooler pipe as its 2.5 and S4 pipe is 2
    The only way that we could fix the leaking was to cut the S4 top pipe and refit it into the RS4 pipe and that worked out very well after second pressure test there was no leaking at all and the car now pulls like a tank so the only thing now is left to take it back to SRR and check the car power again.
    (Audi S4 351.9 PS, 603 Nm, MRC Custom Remap XS Power DP's, Cat Back Exhaust, Forge DV, RS4 Intercoolers, RS4 Breaks and Induction kit)
    Traffic Exchange Site http://www.limehits4u.com/
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    I may be been stupid here but is your drivers tyre running the wrong direction?
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    Well spotted mate, looks like it, now you say it...
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Running like a tank eh? Hope it's quicker than that!
    Glad you've sorted the problem.
    How did you not notice the difference in diameter when originally fitting the hoses? People usually butcher their S4 hoses to act as a sleeve to fit inside the RS4 hoses.
    Mo power, mo problems
    Nez
    Dec 2008
    London
    595
    Quote Originally Posted by Blue_Thunder View Post
    I did notice it and I knew that the S4 hose's are 2" and RS4 are 2.5" but the garage that I fitted the intercooler's he said it should be fine out cut and putting the S4 hose's inside the RS4 and for passager side he was right but for driver side he was wrong
    Nez
    Dec 2008
    London
    595
    Quote Originally Posted by andybnwc View Post
    Thanks for that I will check it soon to see if its in wrong direction
    Sep 2009
    Essex
    2,366
    good thread. nice to see an audi being worked on rather than being sent away to a garage!
    fellow spannerers, im off to the garage to do a cambelt/water pump and most importantly a thermostat change on mine
    Nez
    Dec 2008
    London
    595
    Quote Originally Posted by Matt82 View Post
    The only thining I took the car to garage was to pressure test the intake as I didn't had the tools for it
    Jul 2006
    1,562
    Nothing wrong with taking a car to a garage, so long as it's good reputable one that doesn't pull your pants down.
    I used to do WAY more work on my Vauxhalls than the bits and bobs I do to my Audi these days. Being arsed is one aspect, not having the correct (often expensive) tools is another, but the key for me is time. Family, bands and DIY etc take up my time instead.
    Sep 2009
    Essex
    2,366
    diy is a pain. i got the audi around the same time as i moved, hence couldnt touch the car for weeks at first
    it seems almost fun to get back into doing the greasy stuff, but im so busy in the day ive not actually ordered any of the new bits i need
    will definately pop into audi tomorrow
