JMB RetrofitsChris Nott
Page 3 of 18 FirstFirst 1234567891013 ... LastLast
Results 81 to 120 of 692
Like Tree31Likes
Thread: TQS progress thread, From STD-Scroll-Eliminator.
  1. #81
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    I dont have a boost gauge on mine but i think its meant to be 1 bar its running so should be just shy of 15 psi.
  3. #82
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    Quote Originally Posted by Lee Goodall View Post
    Suppose we could've easily worked that out by just checking the boost pressure on two mapped cars.. one AEB and one AJL.
    Thanks to Aragorn (ASNs answer to Carol Vordeman) we now have proof lol.
    He is a clever one isn't he ?
  4. #83
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    TD5 Land Rover Defender build
  5. #84
    jcb
    Sep 2005
    uk
    4,077
    what do you look like in black dress?
    Show us your consonants!
  6. #85
    Danielson's Avatar
    Jun 2004
    UK
    704
    you lot havent changed much.
  7. #86
    Apr 2004
    12,522
    Righty, now the search works i am able to update slightly.
    My fuel filter gave up and started trowing fuel out so i had to pull the car off the road while i ordered the parts up.
    So much for Service history huh! Good job it went so at least i wont have flow problems with a replacement.
    It wouldn't undo so i had to modify the clamp
    So while it was off road i got jiggy with it.
    Whipped the turbo off after soaking it all weekend in releasing oil ( one for you Lee)
    Before physically removing the turbo i thought i would offer up that DP i made.
    It was too long and needed trimming so i kinda got carried away while the grinder/welder were accessable
    Welds checked by an expert.
    Current exit point while i decide whether to stick flexi then cat or flexi then pipe and cat as per next pic
    Thats my first thought on positioning, to stick the cat there once the Y splitter has been removed back to a single pipe
    My 40 S4 exhaust system, it had to be cut to get it couriered to ne, but no drama, it can be bodged, OOOPS i meant welded.
  8. #87
    Apr 2004
    12,522
    Sorted the MAF problem too i think, the GF bought me a MAF housing from a MK3 VR6 Golf ( OBD1)
    The good thing is the AJL sensor will fit directly in so positioning is accuarate. The fitment of the MAF to the airbox is different, but i am sure i can "fix" that.
    Look at the difference in diameter between AEB/AJL and the VR6
    The downside is the silicone TIP wont fit onto it, no matter how much i try.
    so something like this will be required to fit it.
  9. #88
    Apr 2004
    12,522
    Exit point under car.
    This is more or less how it will sit.
    3inch outlets aded to the 200cell CAT
    Not pretty but functional
    Maf comparison AJL v VR6
    One smiley car
    Bumper trimage
    Ex mani missing in action... Studs will also get removed
    to accomodate this. Only thing i had to do was widen some of the holes to allow clearence for the bolts to slide in. The M8x35 socket head cap screws are just right with the OEM washers
  10. #89
    May 2008
    perth
    1,197
    Is your old turbo a k03 or a k03's? Dont think i have seen a TQS with a k03's yet.
  11. #90
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    so that DP is custom made then huh mark lol fair play to you mate. so can you make your own custom downpipes from any stainless steel?
  12. #91
    Apr 2004
    12,522
    I dont have the gear to weld stainless hence using mild steel ( oh and it's much cheaper)
    Ian, its a lowly K03, already checked
  13. #92
    "Stick a V8 in it!"
    15,384
    Ian: TQS's dont have K03S', They have exactly the same turbo as an AEB.
    Only B5's with the K03S are the APU and similar DBW engines.
  14. #93
    May 2008
    perth
    1,197
    Thats what i thought. I just remember not long ago everyone thought they had a k03's. I was well miffed thinking mine had been swapped for a k03 ha ha.
  15. #94
    "Stick a V8 in it!"
    15,384
    ye i'm not sure where that came from, it did seem to be regularly touted as the AJL having the larger turbo, but it doesnt!
  16. #95
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    Looking good Mark.. no need to rub it in about how easliy your turbo to manifold bolts came out though! lol
    I need to sort my DP connection now too.
  17. #96
    Apr 2004
    12,522
    Had a busy day doing other stuff so this is as far as i got today, a quick grind and shorten the tail ready for the CAT, then thats good to go. Am awaiting some more pipe ( and cash to afford it,lol) so the exhaust has to go on stop for now.
    After that it's time to remove the turbo( still in place for DP fitment) and start putting the hybrid/ fmic on etc
  18. #97
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,585
    Nice work mate
    <tuffty/>
  19. #98
    Apr 2004
    12,522
    Updates above.
    Picture of the turbo with its bits fitted and actuator fitted and set.
    old unit
  20. #99
    Oct 2007
    UK - Midlands
    2,223
    Getting there now mate.. Good work
  21. #100
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Good work Mark!
    Wish I had the time/expertise to do this kind of thing on my own too.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
  22. #101
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Havent driven mine in 3 months I really want a new turbo...
    Drizz Developments - Audi A4 Avant Quattro Sport
  23. #102
    "Stick a V8 in it!"
    15,384
    I'm getting marks old turbo to fix my no-wastegate.
    Why not just get another turbo from eblag and nail it on?
  24. #103
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Well my old AJL car was chipped to 211bhp and would boost to 15psi so if the turbo is not the factor then there must be other things in play but one thing is for sure if a tuner could get 211bhp out of a AEB setup trust me they would so maybe the later K03's are slightly different.
  25. #104
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Because if im going to the trouble of stripping it down, i may as well stick a decent turbo on lol
  26. #105
    "Stick a V8 in it!"
    15,384
    well ye, but if its stopping you driving the car surely sticking a 50quid ebay turbo on for a few months is better than taking the bus?
  27. #106
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    I have 4 other cars lol
  28. #107
    Apr 2004
    12,522
    Righty, been playing again, 3 inch MAF housing with AJL MAF element fitted.
    Note my pikey bracket to secure it
    I was lucky and happened across a bit pipe i could utilise
    Its in, it runs, The TIP aint pretty but i made do
    Is it right to have this many bolts and things left over???
    Oh and for a laugh, i recorded the car running with downpipe only....
    Monster...
  29. #108
    "Stick a V8 in it!"
    15,384
    :D
  30. #109
    Oct 2007
    UK - Midlands
    2,223
    Excellent!.. Looking good to me (apart from the coolant leakage lol).
    Are you running the 3" MAF housing already?
    Bet you can't wait to get the injectors in and the boost cranked up to 30PSI hey?!
  31. #110
    Apr 2004
    12,522
    Leakage ? Spillage due to my dodgy old shakey hands,LMAO
    Yeah Nick said it should be ok, so i will moniter lambda Voltages for now.
    I have had to stop for now, out of cash, need some more migwire and tubing amoung other things so have connected the DP to the TQS exhaust. OMG what a size difference.LOL
    I need the car for a local ish trip so have had to stick it together with gun gum and a reducer thing, as a good mate of mine callled it "pikeytastic"
    So no more progress really till after the weekend as we are busy helping some friends out
  32. #111
    Oct 2007
    UK - Midlands
    2,223
    That's good to know. I will fit the 3" housing with the turbo from the outset then too.. save me getting a temporary reducer which is a bonus.
    Sorry I forgot about your age. A certain amount of spillage is expected then lol.
    Looking forward to seeing it with the full exhaust.
  33. #112
    "Stick a V8 in it!"
    15,384
    I suspect that with that MAF its going to quickly pop a "Adaption Limit Reached - Mixture Weak" code, but we'll see how it goes.
    Keep the N75 unplugged to keep the boost pressure down if your driving it unmapped.
  34. #113
    Oct 2007
    UK - Midlands
    2,223
    I'll be on the standard AGU map until it's remapped. To be safe I will disconnect the N75.. good advice
    Could always push an insert into the MAF housing to reduce the diameter until mapping I suppose.
  35. #114
    "Stick a V8 in it!"
    15,384
    Thats an idea! If you sleeve the MAF down then it should read correctly, Just be a bit tricky getting a "sleeve" that will fit snuggly and not move under load/boost.
  36. #115
    Apr 2004
    12,522
    Hopefully the last few bits required to fit the exhaust. Will have a play tomorrow and see what occurs.
    The one is a clamp on to fit the S4 Exhasut to the 3 inch section, and the other is a weld on sleeve to allow me to make the pipe slide over the cat pipework.
  37. #116
    jcb
    Sep 2005
    uk
    4,077
    what is 3"? the downpipe?
    I need to join a 3" DP to a 2.75" middle section somehow. may try your reducer pipe trick if there is a big gap.
    WHere did you get it? is it stainless?
  38. #117
    "Stick a V8 in it!"
    15,384
    Yeh the downpipe is 3".
    Perhaps something like this:
    https://www.jetex.co.uk/jetex/store/...productId=2823
  39. #118
    jcb
    Sep 2005
    uk
    4,077
    yes, that is what I saw.
    I suspect that the 2.75" pipe will fit inside the DP quite well but it makes the step on the wrong side. Not a huge issue. one more thing to work out
  40. #119
    Apr 2004
    12,522
    Right some progress
    TQS system off
    Although i prefer the tail pipes on the TQS system over the S4 the dia of the pipework hampers me swapping them.
    TQS
    S4 ( i know its not centered yet, its all still loose)
    I now wish i had taken more time to get a better exit point for the DP and an entry point into the S4 system as the centre section is kind of "not straight. Some time taken here would have helped me... Next time hey.
    DP, see how close it is to the tunnel? Causes a few issues
    The S4 rear with my dodgy @rse CAT on it again, not as centeral as i would like
    And the not straight centre section pre grinding...
    I am still confident as long as it is airtight, it still has to be better than the TQS system, 3 in DP and centre to 200cell CAT and 65mm S4 exhaust system. I have seen S4s push 300BHP easily on std systems so this should do fine for me at the cost of 120 all in with CAT.
    Have i taken De badging a bit far?
    Nope i finally have my plate back, thanks to Lee for looking after it for me.
    Will stick the sysytem together and post sound clips in the week for reference
  41. #120
    jamie226bhp's Avatar
    Aug 2009
    464
    Any major problems fitting the s4 exhaust, as thinking of buying a 200 ebay one and making it fit mine but yours looks single pipe and the ebay one's are twin all the way through
  1. my new s3 8l progress thread
    By s3schofield in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2014, 18:59
  2. RS4 b5 progress thread
    By colicabcadam in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 10th December 2012, 11:25
  3. my avant progress thread
    By rawtor51 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th July 2012, 21:37
  4. Progress Thread
    By MickM in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2010, 21:29
  5. Scroll SP51 thread
    By docurley in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st July 2008, 20:31
Tags for this Thread
