JMB RetrofitsSky Insurance
Page 15 of 18 FirstFirst ... 589101112131415161718 LastLast
Results 561 to 600 of 692
Like Tree31Likes
Thread: TQS progress thread, From STD-Scroll-Eliminator.
  1. #561
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    never see 400 in a million years, US hp maybe, but not good old fashioned UK genuine BHP.
    Id be expecting 320 ish with 360 Ft lbs and solid low spool to make for a quickish car.
    I just need a clutch that can handle it, mine slips on NLS
  3. #562
    RIP S3dave
    May 2004
    nr Glos
    7,195
    Quote Originally Posted by Byzan Pics View Post
    It would seem that the vvt is active quite early on and has a profound effect on the way the car drives.
    Research needed on revs it's active.
    VVT, active when -4 (22 deg)
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  4. #563
    Apr 2004
    12,523
    That proves what I felt then, the car is deffo livlier when it's active. I'd guess it's also what's affecting my part throttle/ low rev running or stumbling, maybe aiding the car in poping back due to overlap
  5. #564
    gmx
    Feb 2009
    Sydney
    133
    Are you using VVT with standard AJL cams?
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R Elim | Custom ME5 | 034 3" DP | 034 HFM | 034 TIP | ER Comp IC
  6. #565
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    yep he is.
    TD5 Land Rover Defender build
  7. #566
    RIP S3dave
    May 2004
    nr Glos
    7,195
    simple to check by resetting the vvt, on cold start maps to nothing to see how thats effecting things on cold cycle vs warmed up vvt mode
    www.badger5.biz
    bill@badger5.co.uk
  8. #567
    Apr 2004
    12,523
    yeah what he said ^^
  9. #568
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Do those adaptors fit yet mark?
  10. #569
    Apr 2004
    12,523
    TBH bud, I've not tried them, I see no reason why not.
    I need to find the cash to order the valve spring,retainers and a cam then try and blag a ramp for a few days @ Bills. But Bill is flat out ( good for business) and I'm skint,lol
    The biggest issue with mine atm is the 1 litre a week of oil she is drinking, It's almost a 2 stroke....
    Also I got ripped off on a VVT that was supposed to be genuine, but it wasn't and i have had to stump up an additional fee for customs and return postage to get this sorted that I wasn't expecting.
    At this rate, I'll be driving my daughters 1.1 Clio so I have a reliable car..........GULP
  11. #570
    Apr 2004
    12,523
    A few bits to fix the head.
    Supertech valves and seals
    Tubular ex manifold, Devills own WMI kit and a wellycooler
    Hopefully this should stop it bottle necking and excess heat being generated
    Inlet cam specs VVT safe apparently
    Side by side with a std 1.8t cam
    This is the "matching" exhaust cam as recommended by CAT, I have to say the spec is so similar to the 3665 designated cam anyway, i'd bet they are the actual same part, but designated differently depending on the inlet pairing
    Exhaust cam side by side
  12. #571
    Apr 2004
    12,523
    I am attempting to do all this in 2 weeks provided all goes well with the baby due tomorrow. That should stop my car being a damned 2 stroke and a a heat pump so Bill can work his magic on it for me and install the multi maps on it, One to be banzai WMI dependent, and then one as good as it can be without WMI, but will prob run it for cooling. Then an actuator only jobbie.
  13. #572
    boost-addict's Avatar
    Aug 2011
    977
    Looks sweet. Congrats ahead of your childs birth.
    How agressive are those cams? Allways wondered if you can mild cam a 1.8t without a remap
  14. #573
    Apr 2004
    12,523
    I asked for OEM idling and not massive overlap because it seem the 1.8t isn't happy with huge overlaps. I'm not sure on gains yet, and my car will be mapped to take account of them, even if it's just a slightly higher rev limit IIRC it currently stands at 7800. I'm hoping the extra flow will allow power to be made easier and then stop the damn thing turning boosts and timing into heat,lol
  15. #574
    Apr 2004
    12,523
    I've done some tinkering while waiitng for parts
    Tubular manifold tweaked and test fitted
    Bill got in there with his die grinder
    Some more pics on his FB
    ARP bolts fitted to everything I can feasibly do
    Lucky escape here
    Waiting for an ARP crank bolt and an IE top pulley and bolt to come from IE to properly get into it and assemble the head properly, then we can look at timing the cams up properly using Bills special tool for cam timing from IE, curious to see how much the std marks are out in regards to where they end up
  16. #575
    Apr 2004
    12,523
    A few logs from today. WMI on but only water and still on actuator only, so 1 bar boost AFR at top of 12.3 ish. She is now fitted with an EGT probe so will ask Nicely to get it enabled and we can log that too
    MAF scaling is STD so that can be relied upon in the /.8 for BHP ( 327 on actuator). But load is maxed out
    Code:
    28 June 2013 18:31:18
    1.8L R4/5VT G03 0004
    Group A: '002 Group B: '003 Group C: '020
    Engine RPM Engine Load Ave. Inj. Period Air Mass Flow Engine RPM Air Mass Flow Throttle Opening Ign. Timing Cyl #1 Cyl #2 Cyl #3 Cyl #4
    TIME TIME TIME
    STAMP /min % ms g/s STAMP /min g/s % °ATDC STAMP CF CF CF CF
    3.8 2600 34.6 2.04 11.06 4.31 3800 14.44 8.2 14.3 4.71 0 0 0 0
    5.11 3680 46.6 3.74 33.47 5.61 3680 34.89 17.6 33 6.01 0 0 0 0
    6.42 3760 60.9 4.42 44.78 6.92 3800 45.06 20.8 32.3 7.32 0 0 0 0
    7.72 3840 75.2 5.1 56.89 8.14 3880 52.72 23.1 30 8.63 0 0 0 0
    9.03 4040 66.2 4.76 49.75 9.43 4040 49.14 22 31.5 9.83 0 0 0 0
    10.25 4120 54.9 3.74 43.64 10.74 4120 43.58 20 33 11.14 0 0 0 0
    11.65 4200 51.9 3.74 40.61 12.05 4200 40.61 19.2 33.8 12.45 0 0 0 0
    12.85 4200 43.6 3.4 35.08 13.25 4200 35.31 17.6 35.3 13.65 0 0 0 0
    14.07 4040 13.5 1.36 12.83 14.57 3240 8.94 5.5 2.3 14.95 0 0 0 0
    54.9 2840 36.1 2.72 18.5 55.29 2720 5.61 7.8 35.3 54.4 0 0 0 0
    56.11 3880 33.1 2.72 24.81 56.51 4000 87.06 94.9 27.8 55.69 0 0 0 0
    57.41 4360 191.7 13.26 164.33 57.81 4560 174.03 100 15.8 56.91 0 0 0 0
    58.62 4880 191.7 13.6 183.39 59.02 5040 191 100 10.5 58.22 0 0 0 0
    59.82 5360 191.7 14.62 209.86 60.22 5520 222.97 100 12 59.42 0 0 0 0
    61.04 5840 191.7 15.64 231.97 61.44 6000 238.61 100 12 60.62 0 0 0 0
    62.33 6320 191.7 15.3 250.69 62.75 6440 253.14 100 12 61.84 0 0 0 0
    63.65 6760 191.7 14.62 257.56 64.05 6840 259.44 100 12 63.15 0 0 0 0
    64.86 7080 191.7 14.62 262.56 65.26 7200 262.06 100 13.5 64.45 0 0 0 0
    66.06 7440 185.7 14.28 262.06 66.46 7120 0 9.8 18.8 65.66 0 0 0 0
    Code:
    28 June 2013 18:39:09
    Group A: '004 Group B: '003 Group C: '020
    Engine RPM System Voltage Coolant Temp. Intake Air Temp Engine RPM Air Mass Flow Throttle Opening Ign. Timing Cyl #1 Cyl #2 Cyl #3 Cyl #4
    TIME TIME TIME
    STAMP /min V °C °C STAMP /min g/s % °BTDC STAMP CF CF CF CF
    497.96 2120 13.58 81 23 498.36 2080 5.03 3.5 2.3 497.57 0 0 0 0
    499.28 2040 13.72 81 23 499.69 2040 4.94 3.5 1.5 498.78 0 0 0 0
    500.59 2120 13.65 81 23 501.1 2160 43.97 94.9 12.8 500.19 0 0 0 0
    501.9 2280 13.86 81 21 502.3 2360 51.08 95.3 13.5 501.5 0 0 0 0
    503.1 2480 13.58 81 20 503.51 2560 65.11 96.1 12.8 502.7 0 0 0 0
    504.41 2760 13.79 81 20 504.91 2880 91.83 98.8 13.5 504.01 0 0 0 0
    505.72 3080 13.72 81 19 506.12 3200 102.97 100 15.8 505.32 0 0 0 0
    506.92 3400 13.72 81 18 507.34 3520 114.42 100 18 506.52 0 0 0 0
    508.14 3760 13.72 81 18 508.54 3920 136.92 100 18 507.74 0 0 0 0
    509.34 4080 13.65 81 19 509.74 4240 153.78 100 15.8 508.94 0 0 0 0
    510.65 4480 13.65 81 20 511.05 4520 163.69 99.6 16.5 510.15 0 0 0 0
    511.86 4760 13.58 82 20 512.36 4880 183.67 100 12 511.45 0 0 0 0
    513.16 5040 13.51 81 21 513.56 5080 193.33 100 12 512.76 0 0 0 0
    514.38 5200 13.44 81 21 514.87 5320 203.44 99.6 11.3 513.98 0 0 0 0
    515.67 5480 13.51 81 22 516.09 5560 220.5 100 12 515.27 0 0 0 0
    516.89 5680 13.51 81 23 517.29 5760 229.89 100 12 516.49 0 0 0 0
    518.2 5920 13.44 81 24 518.6 6000 237.86 100 12 517.69 0 0 0 0
    519.4 6120 13.37 81 24 519.8 6160 243.11 100 11.3 519 0 0 0 0
    520.62 6280 13.58 81 24 521.11 6400 251.97 100 11.3 520.2 0 0 0 0
    521.91 6480 13.58 81 25 522.31 6560 253.14 100 12.8 521.51 0 0 0 0
    523.22 6680 13.58 81 26 523.62 6720 259.56 100 12.8 522.73 0 0 0 0
    524.44 6840 13.51 81 26 524.84 6880 262.28 100 11.3 524.02 0 0 0 0
    525.64 6960 13.37 81 26 526.13 7000 265.92 100 12 525.24 0 0 0 0
    526.95 7040 13.44 81 27 527.35 7120 262.56 100 12 526.53 0 0 0 0
    528.15 7200 13.37 82 27 528.55 7240 266.61 100 12 527.75 0 0 0 0
    529.35 7120 13.79 83 24 529.77 7040 21.92 8.6 10.5 528.95 0 0 0 0
  17. #576
    "Stick a V8 in it!"
    15,389
    Looking good!
    What else needs done before you get a final tune sorted then get 4wd back?
  18. #577
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
  19. #578
    Apr 2004
    12,523
    http://static.photobucket.com/player...ps0add5df7.mp4.
    Spur of the moment no lift shift from the tolls
    <tuffty/> likes this.
  20. #579
    Aug 2010
    3,138
    it wont bloody work on my iphone goes to bump app then tells me to connect to itunes
  21. #580
    Apr 2004
    12,523
    Code:
    21 August 2013 18:59:54
    Group A: '003 Group B: '020 Group C: '115
    RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Load Absolute Pres. Absolute Pres.
    TIME TIME TIME
    STAMP /min g/s % °BTDC STAMP CF CF CF CF STAMP /min % mbar mbar
    0.73 2840 20.67 12.2 31.5 1.03 0 0 0 0 0.43 2840 39.8 1010 1070
    1.64 2800 18.25 11 31.5 1.94 0 0 0 0 1.34 2840 36.1 1010 1060
    20.64 3960 9.19 6.3 3.8 20.95 0 0 0 0 21.25 3880 11.3 1010 1040
    21.55 3880 8.81 6.3 3.8 21.85 0 0 0 0 22.16 3800 16.5 1010 1040
    22.46 3960 64.89 49.4 28.5 22.76 0 0 0 0 23.06 4000 130.8 2550 1460
    23.36 4120 162.56 100 17.3 23.66 0 0 0 0 23.96 4480 191.7 2550 2370
    24.27 4680 205.25 100 12.8 24.57 0 0 0 0 24.87 5000 191.7 2550 2370
    25.17 5160 225.83 100 10.5 25.47 0 0 0 0 25.78 5480 191.7 2550 2470
    26.08 5680 252.75 100 10.5 26.38 0 0 0 0 26.68 5960 191.7 2550 2440
    26.98 6120 263.08 100 11.3 27.28 0 0 0 0 27.58 6360 191.7 2550 2360
    27.89 6520 266.72 100 11.3 28.2 0 0 0 0 28.5 6760 191 2550 2220
    28.8 6840 270.22 100 11.3 29.09 0 0 0 0 29.4 7040 191.7 2550 2180
    29.72 7160 270 100 12.8 30 0 0 0 0 30.3 7360 191.7 2550 2170
    30.6 7400 272.81 100 12.8 30.9 0 0 0 0 31.21 7320 16.5 1010 2350
    I may have accidently plugged the N75 back in I have some boost 1.3 bar ish AFR stable . 3rd gear logged as best as possible at hometime.
    WMI is on but only filled with water for additional cooling.
  22. #581
    Aug 2010
    3,138
    So what figure you seeing then HP wise ?? Also whats the method for calculsting this off the maf g/s ??
  23. #582
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    341bhp!
  24. #583
    RIP S3dave
    May 2004
    nr Glos
    7,195
    very promising.
    very low ign, no CF... more boosts in there... muaha ha ha haaaaa
    *cough*
    www.badger5.biz
    bill@badger5.co.uk
  25. #584
    beachbuggy's Avatar
    Surrey
    1,746
    Who said eliminators don't work..
    looks very impressive so far.. Nice work..
  26. #585
    Apr 2004
    12,523
    yup 337 and 280 on B5 rollers today .
    a little to come, perhaps on multi map with banzai wmi dependant map just to see what she can do.
    only things left to do is get some replacement discs as mine are warped a little and it's really noticable now, and fit my shiny wheels if they ever come back...
    logs and plot to come when i remember to ask for it,lol
  27. #586
    "Stick a V8 in it!"
    15,389
    tis awesome to see your finally getting there with the power output! Its taken a while, but things have finally worked out!
    Just need to get it back on 4wd now!
  28. #587
    Apr 2004
    12,523
    and a few logs of before and after
    This was a log with the N75 on on the last file, space for timing and some better fueling up top to allow for additional cooling to aid keeping the EGT's sensible, still need to enable the sensor to see how it's doing. The colour of the manifold seems to point to be it being fecking hot
    Code:
    Friday 23 August 2013 15:33:40:41334 VCDS Version: Release 11.11.6 Data version: 20121223
    8N0 906 018 H 1.8L R4/5VT G03 0004
    Group A: '003 Group B: '020 Group C: '118
    Engine Speed Mass Air Flow Throttle Valve Angle Ignition Timing Retardation Timing Retardation Timing Retardation Timing Retardation Engine Speed Intake Air Boost Pressure Boost Pressure
    TIME (G28) Sensor (G70) Timing Angle TIME Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4 TIME (G28) Temperature (G42) Control (N75) (actual)
    Marker STAMP /min g/s % °BTDC STAMP °KW °KW °KW °KW STAMP /min °C % mbar
    14.49 1680 24.08 21.2 16.5 14.8 0 0 0 0 15.1 1680 30 95.3 1100
    15.39 1680 29.36 78.4 14.3 15.7 0 0 0 0 15.99 1720 28 95.3 1130
    16.29 1720 30.14 78.4 12.8 16.61 0 0 0 0 16.91 1720 27 95.3 1150
    17.2 1720 28.89 78.8 12 17.5 0 0 0 0 17.8 1960 27 95.3 1170
    18.1 2120 42.03 94.9 12 18.41 0 0 0 0 18.72 2400 27 52.2 1260
    19.02 2520 56.56 94.9 17.3 19.31 0 0 0 0 19.62 2840 27 42 1430
    19.92 2960 80.61 99.6 15 20.23 0 0 0 0 20.52 3280 28 40 1850
    20.83 3440 129.94 100 14.3 21.12 0 0 0 0 21.43 3760 29 40 2260
    21.73 3920 155.83 100 12.8 22.03 0 0 0 0 22.34 4160 30 40 2340
    22.64 4280 179.06 100 14.3 22.94 0 0 0 0 23.24 4560 30 40.8 2380
    23.54 4680 195.69 100 12 23.85 0 0 0 0 24.15 4920 30 44.3 2440
    24.45 5000 223.64 100 10.5 24.75 0 0 0 0 25.05 5320 32 45.1 2470
    25.36 5440 243.89 100 10.5 25.66 0 0 0 0 25.96 5720 33 45.1 2450
    26.26 5840 253.78 100 9.8 26.56 0 0 0 0 26.86 6080 33 45.1 2400
    27.16 6200 259.44 100 10.5 27.47 0 0 0 0 27.77 6400 33 45.1 2290
    28.07 6520 264.58 100 10.5 28.37 0 0 0 0 28.67 6800 34 45.1 2210
    28.97 6920 266.11 100 11.3 29.28 0 0 0 0 29.58 7160 34 45.1 2160
    29.88 7240 267.14 100 11.3 30.18 0 0 0 0 30.48 7480 35 45.1 2100
    30.79 7360 260.56 54.9 -7.5 31.1 0 0 0 0 31.39 6000 27 0 1370
    Code:
    Friday 23 August 2013 17:34:05:41334 VCDS Version: Release 11.11.6 Data version: 20121223
    0.3 1600 14.17 9.8 29.3 0.62 0 0 0 0 0.02 1600 33 0 1030
    1.24 1600 14.19 9.8 29.3 1.51 0 0 0 0 0.9 1600 33 0 1030
    2.11 1600 14.03 9.8 29.3 2.42 0 0 0 0 1.82 1600 33 0 1030
    3.03 1600 13.94 9.8 29.3 3.32 0 0 0 0 2.71 1600 33 0 1030
    3.93 1600 14.31 9.8 27.8 4.22 0 0 0 0 3.62 1600 33 0 1030
    4.83 1600 14 9.8 29.3 5.13 0 0 0 0 4.52 1600 33 0 1030
    1 5.73 1600 14.89 10.2 28.5 6.04 0 0 0 0 5.44 1600 33 0 1030
    6.64 1640 23.83 21.2 20.3 6.94 0 0 0 0 6.34 1640 33 0 1030
    7.55 1640 28.36 100 15 7.84 0 0 0 0 7.25 1640 32 95.3 1060
    8.45 1640 26.83 100 14.3 8.75 0 0 0 0 8.15 1640 31 95.3 1090
    9.36 2040 37.31 100 15.8 9.66 0 0 0 0 9.05 1880 30 95.3 1130
    10.27 2480 51 100 18 10.57 0 0 0 0 9.97 2320 30 73.3 1210
    11.17 2880 71.06 99.6 20.3 11.47 0 0 0 0 10.87 2760 29 45.1 1340
    12.08 3360 112 100 19.5 12.38 0 0 0 0 11.78 3200 29 45.1 1630
    12.98 3880 163.81 100 15 13.28 0 0 0 0 12.68 3680 28 45.1 2210
    13.89 4360 183.58 100 18 14.19 3 0 0 0 13.59 4240 27 45.1 2390
    14.79 4800 217.58 100 17.3 15.1 3 0 0 0 14.49 4640 26 45.1 2410
    15.7 5200 234.89 100 17.3 16 2.3 0 0 0 15.4 5080 27 44.7 2430
    16.6 5600 246.94 100 18 16.91 2.3 0 0 0 16.3 5480 28 43.5 2380
    17.51 5960 255.89 100 18.8 17.81 1.5 0 0 0 17.21 5840 29 49.8 2350
    18.41 6320 263.89 100 17.3 18.71 1.5 0 0 0 18.11 6200 30 58 2270
    19.32 6680 267.14 100 19.5 19.63 0.8 0 0 0 19.02 6560 31 58 2260
    20.22 7000 271.25 99.6 18 20.53 0.8 0 0 0 19.92 6880 32 58 2200
    21.13 7320 272.28 100 18.8 21.43 0 0 0 0 20.83 7200 33 58 2200
    22.04 7680 273.33 99.6 18 22.34 3 3 0 0 21.73 7560 33 58 2210
    after some timing and boost stabilisation
  29. #588
    Aug 2010
    3,138
    Thats some good bhp/torque to have some fun with !!
    So whats next in the process mark ?? You almost there ??
    you popping it back to 4WD now or still more fine tuning to do whilst 2WD ??
  30. #589
    Apr 2004
    12,523
    I think i'll tidy it up stuff the proper diff back in and sell her on. 50/50 atm.
    No more upgrades i just cannot afford them, I wish i'd chosen a larger frame turbo I have built an engine capable of supplying 500 bhp and it's barely idling...
    If she goes, it will be for something very std and boring.
  31. #590
    Aug 2010
    3,138
    sell WTF you taking the piss !!
    break the damn thing if anything !! You will probably get more for it in parts !!
    Arrkon likes this.
  32. #591
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    498
    No way, keep it and enjoy all the effort you have put in!!
    ScottD3 likes this.
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
  33. #592
    "Stick a V8 in it!"
    15,389
    Really is no point selling it! You'll get ****e all back compared with what you've put in.
    Drive, Enjoy.
  34. #593
    Apr 2004
    12,523
    From them
    to them.
    Now thanks to Matt @ Cat cams for sending me the replacement bolts for my cam gears i am hoping to fix the mechanical cam to cam timing because it's showing as 11-12 degrees out.
    Wheels are back from machine shop, I just need to fix my mullered wing to enable satisfactory fitment . They removed 12mm from the back, so with a slight flare I recon we are good to go
  35. #594
    Apr 2004
    12,523
    Some phone snaps after their annual wash.
    They both need some TLC but moving and having a roof over our heads seemed to be more important
  36. #595
    Apr 2004
    12,523
    Nothing good to report, I managed to score a pair of front wings in the same colour in much better condition than mine so i'll roll them and nail them on when I get some motivations back.
    She just needed some tidying but my rattle has come back, so I had had to purchase some more rods to eliminate downtime during the swap over. At the same time I am putting another crank in just to be sure/ Parts are mostly collected for that project until....
    https://www.dropbox.com/s/ij2v0yjr9u...113_132133.mp4
    Can you guess what it is yet......
    This may delay things a bit, I was kind of hoping to fix the rattle and be done, it seems the turbo fairy had other ideas
  37. #596
    Aug 2010
    3,138
    That doesnt sound good, is that the turbo on engine cut off making that noise ??
    Havent you just swapped the oil pump hows the oil pressure ??
  38. #597
    Apr 2004
    12,523
    Dan @ beach buggy has come up trumps.
    I am using my spare chra I kept and having this shiny lot fitted to it.
    Std comp wheel and gt 30 turbine (57mm by 52mm) I need to get my fubar turbo off to BBT to allow for the turbine housing to be machined to match.
    We have been trying to locate an upgrade bearing pack, Owens do one but i believe they will only fit at point of turbo repair or purchase.
    I have found these guys.. New silicone nitride ball bearing packs available | Turbocare..
    I might go for it of my bearing is broken, but if mine is perfect as it should be, I'll hang on till a reliably sourced unit is available for possible future upgrade. With these guys it's around £212 plus carriage delivered, with brass bearing cages
  39. #598
    Aug 2010
    3,138
    That will give some good hp figures !!
    Are you selling up or not make your bloody mind up lol
  40. #599
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,095
    Keep it and make it better
    I keep dabbling with changing mine but it still scrubs up well even with its age and miles.
    Life begins at 140mph
    www.passionford.com
  41. #600
    Apr 2004
    12,523
    It's official the turbo is broken/dead/fubar. Replacement turbine and Comp wheel were going to be the order of the day, but it turned out my housing was beyond repair. So the closest thing available is a gt30 compact style housing. That should mean the CHRA will drop in direct, but my manifold, downpipes and that will need tweaking.
    There are other options on the table being explored
    The engine is in bit and the crank was checked and found to be perfect. This has led to a dilemma because I know it had a noise i want to track down, but I was hoping to see something wrong.
    I am aiming to change the IM bearings while i'm in the engine as it has since come to light that they are available.
    I have also resolved my bodywork "issue"
    and it seems my seats have fallen out.....
    I wonder why?
  1. my new s3 8l progress thread
    By s3schofield in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2014, 18:59
  2. RS4 b5 progress thread
    By colicabcadam in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 10th December 2012, 11:25
  3. my avant progress thread
    By rawtor51 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th July 2012, 21:37
  4. Progress Thread
    By MickM in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2010, 21:29
  5. Scroll SP51 thread
    By docurley in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st July 2008, 20:31
Tags for this Thread
