AH FabricationsEM Tuning
Page 12 of 17 FirstFirst ... 2567891011121314151617 LastLast
Results 441 to 480 of 644
Like Tree28Likes
Thread: TQS progress thread, From STD-Scroll-Eliminator.
  1. #441
    jcb
    Sep 2005
    uk
    4,070
    what you doing with the old turbo?
    is it a stock one? (sorry didnt scroll through whole thread)
    I may need one
  3. #442
    gmx
    Feb 2009
    Sydney
    132
    looking great Mark..
    how are the blue (autobahn88?) hoses holding up?
    Looking forward to the ME7/DBW stuff!
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R - 13psi | Uni 415cc@4bar | 034 3" DP | 034 HFM | 034 TIP | Profec B Spec II
  4. #443
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    The AB 88 hoses are great still. Only reason they have been changed is because i have had larger dia pipes fitted. 63mm instead of the 51mm. To add more flowability with the larger TIP.
  5. #444
    Apr 2004
    12,354
    Some progress today.
    I fitted the pedal box to the car with the extended mount for the new throttle pedal.
    It resides under this lot
    It requires removal of the servo master cylinder assy on RHD for certain. So i am going to need to bleed the clutch and brakes. On the plus side, she was due a fluid change....
    While the loom was out i did the ICM delete with the B6 loom section 1JO 971 658 L, much cheaper than the repair looms you get.
    I chose a loom from a 2000 Passat / A4 as it was sort of an in between model. Still had dumb coils, but no silly second Lambda probes or SAI etc.
    The loom i used was 8D2 971 072 FQ. It plugs in directly to my 99 Facelift car loom with 99% the same connections.
    This does come with a few problems like it's still a narrow band ECU, it is however still ME7 and fully flash-able and readable and tweak-able using Unisettings and the like .
    I have added a connection for the engine light, from the orange plug to the blue dash plug pin 13.
    On that same plug there is 2 black/blue wires, but the car side loom only has one, so i have bridged them to allow 12v .
    The new loom expects to see the combined sump oil condition / temp sender . I checked and the wire that goes to the dash is the same for oil temp on both looms, so i just made the connection fit my old style sender.
    The MAF housing is different orientation to the old AEB/VR6 Combo i had previously.
    The new style CTS was also required.
    And a position welded to my FMIC pipes for the MAP sensor which would normally live on top of the OEM SMIC
    May have added a boss for WMI while it was being done.
    Throttle body needed to be changed to a DBW one, Not the studs, i found the normal TB bolts were too short so i made do with some studding and nuts i already had.
    My chosen ECU is
    4B0 906 018 AA Me7 ECU. Has so far read fine via Galleto and VAGcom
    I had to add a N249 valve, even though i am not using it as such, the ECU needs to see the electrical connection.
    The next hurdle is the Lambda sensor, even though both my car and the new setup are narrowband there is a difference of connection
    For now i will splice it in, but will buy a new sensor, my old one has done 140K, so is probably passed its sell by date.
    Now, here we are. Mostly together but..
    She will not start, i can access ECU via Vagcom and it throws a code for faulty ECU relay 17925. I have a new one fitted but it seems that the 109 (1J0 906 381A) designation is incorrect despite the spades being correct.
    I have ordered a 30 (165 906 381) for collection tomorrow, fingers crossed as i am too far into this to go backwards now.
    Excuse the "snaps" lol
  6. #445
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,652
    How the FIS?
    Any good?
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
  7. #446
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Quote Originally Posted by scott b5 View Post
    How the FIS?
    Any good?
    I too am interested mark... what did it set you back? and do you know if it works with the normal A4 (screen) cluster or just the s4
    Currently rolling in a SKODA!!!
  8. #447
    gmx
    Feb 2009
    Sydney
    132
    Screw the FIS, the ME7 swap is more important here.
    Nice writeup Mark!
    What's the resistance of the N249?
    Is that ECU ME7.1? Once you get it started, you could try a ME7.5/WB ECU.
  9. #448
    Apr 2004
    12,354
    The 7.1 to 7.5 is a planned upgrade, maybe sooner than i thought due to a likely faulty ECU
    I think i have blown something attempting to start it with the incorrect relay
    17925/P1517/005399: Power Supply Relay for ECU (J271 or J363): Electrical Malfunction.
    and
    17987 - Throttle Actuator (J338): Adaptation Not Started P1579 - 35-00 - ...
    Google suggests it the parts themselves check out, the ECU is U/S
    I like to leave the solenoids plugged in as i have seen the pull down on resistors cause ECU and wiring issues that are hard to trace. I'll just fit them with short wires and leave them in the ECU box or code them out.
    The FIS is great, It would be better if i could find someone to solder me a new screen into my dash though. What i can see of it is good,lol
    I am assured it will work on pretty much any A4 with a Dis screen and stalks as std
  10. #449
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    You always take it to a whole new level, i hope it all works out.
  11. #450
    Apr 2004
    12,354
    Update.
    SHE RUNS.......
    No idea if she drives as i have no brakes as i broke the plastic retaining bracket that holds the servo rod to the brake peddle. I ordered one, but stupidly got LHD and now no where open till the morning
    I had to add a wire from the white DBW plug and patch it to the relay to power up the throttle body / pedal. somehow missed that one.
    The non start issue i had after that was a stupid rookie mistake and i had some wiring on the coil loom transposed.
    So the fruits of my labour cannot be realised until wednesday because VW will need to order the plastic thing for delivery Wednesday no doubt.
    To add insult to injury, the reliable Golf is using water like a good en, and i cannot see if going anywhere so as a result cannot drive that far either.
    It never rains....
    I will get a video / sound clip later.
    She seems to idle and rev as she should but i am seeing a Signal too low signal from the MAF,, so i can assume it's either dead, or doesn't like the larger housing.
    It may be this that's causing the ECU to pull 25% fuel out at idle, this has not changed even when i put a 3 bar FPR in to remove 15% fuel manually it's still pegged Flat out on lambda control.
    It could be a consequence of the bad MAF or the map needs tweaking.
    The worst is unisettings won't talk to it correctly so cannot remove some fuel via ECU base adjustments
  12. #451
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,503
    "just"? It only took you two years :P
    I've been looking at some SAAB and Volvo turbos with a view to making some sort of poverty-spec turbo upgrade. Just need to wait patiently on ebay.
    Aragorn.....Which SAAB turbo unit you after? I have a blown turbo (oil/water cooled) and a fully working (oil only cooled) unit, but they are from the early 900 B202 engines.
    Dan
    2002 2.5 V6 Quattro
  13. #452
    gmx
    Feb 2009
    Sydney
    132
    Good news!
    How's HVAC controls and dash itself?
  14. #453
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Good work.
    Are you still using the LET injectors?
    LET injectors on 3 bar are roughly the same as the standard APU injectors in terms of flow, so its understandable that the MAF housing upgrade is going to have the fuelling adaption off the scale.
    It should also be adding fuel, not taking it out? Without any adaption, the bigger maf will cause the engine to run lean?
    Its probably wise to stick the standard 2.5" maf on the car for now and make sure everythings working correctly, before going on to try to tune it?
    TD5 Land Rover Defender build
  15. #454
    "Stick a V8 in it!"
    14,900
    Quote Originally Posted by S4_dan View Post
    Dan
    If i was doing it, i'd have been wanting a TD04 from a 9000 Aero, however i've since discovered the way the bolts attach to the turbine housing would prove problematic, as aftermarket manifolds are typically threaded and expect the turbo to simply have thru holes, whereas the saab and volvo turbos both have studs fitted and require nuts on the manifold.
  16. #455
    Apr 2004
    12,354
    Quote Originally Posted by gmx View Post
    Good news!
    everything works bar the oil temp, but that's a simple wire swap. I have not tried the cruise yet as i have no brakes.
    I have to be honest i haven't wired the load sense for the hvac to ECU, but it doesn't seem to mind at the mo
    I have the 99 dash with analogue clock, not digital. That would require a different engine loom to match the later dash is all.
  17. #456
    Apr 2004
    12,354
    UPDATE.
    Car drives, the daft broken plastic thing for the brakes was £2.51, whole car down, just for that...
    Anyway, decided that because the MAF was showing a low signal so was obvisoulsy faulty as the wiring had been beeped through fine.
    I located a new Bosch unit from ECP and used the AudiSRS discount code and got it for £60 for a genuine Bosch.
    I bled the brakes and found that as soon as started the car would idle a min and cut out, and if revved to keep it running it "felt" it was running out of fuel, disconnected the new MAF and she idles fine, like she did on the old non working MAF
    Anyone had this before?
    Maf off the car drives fine, bar the engine light on, when connected the low signal fault goes and there are readings in vagcom but the car cuts out. Faulty MAF?
    She sounds poorly due to the blowing exhaust, i think the wiggling around has seen it off.
    So i need to buy some stainless tube sooner rather than later and get this fixed. BOOOOO
  18. #457
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Hey I need a new maf sensor pm the code and link for it please mark that's if it's the stock TQS sensor.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
  19. #458
    Apr 2004
    12,354
    Bradderz, I have an almost new genuine one for a TQS if you need it?
    Mine now uses a different sensor now
  20. #459
    Aug 2010
    2,866
    Quote Originally Posted by Byzan Photography View Post
    PM me a price posted mate.
  21. #460
    jcb
    Sep 2005
    uk
    4,070
    wish I had known that last week when I shelled out £102 for a recon unit!
  22. #461
    "Stick a V8 in it!"
    14,900
    Mark: Are you still pinned against the adaption limit?
  23. #462
    Apr 2004
    12,354
    not checked today actually, probably DIS is ready 5MPG currently,lol
    Learned values are nil, but as soon as it drops off cold start map, it pulls 25% out
  24. #463
    Apr 2004
    12,354
    Update.
    Dis MPG fixed, that was a wire swap.
    The running issue was a dead newly supplied MAF unit, I borrowed one and tried it and it was perfect.
    Now I was running on a STD ECU, but when the wiring was done i thought i'd change in the stage 1 ECU. Took it for a blast and quickly realised i had left the N75 connected.
    I thought while it's connected i'd do a "test" run and log some stuff, All went well.
    Lifted and continued to cruise, I pulled up to over take and my car picked up a dose of ScoobyItus...
    Pulled up at Bills a few mins later still plonking around on 3, Upon checking the simple things it turned out i had Spark, Fuel, but no compression.
    Heres why.
    After seeing that it's pretty evident that the valve would have been cracked, but my stupidity running it lean/Untuned built the heat up. This caused a hot spot.
    The pistons and bores seem to have survived, I wonder where the section of valve went.....
    Ahhhhh .....................
    So boys and girls, it just proves that even a quick blast on a badly tuned car can cause problems.
    I will update tomorrow while i re build the head and work out what to do next.
  25. #464
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Gutted for you, was the turbo new?
  26. #465
    "Stick a V8 in it!"
    14,900
  27. #466
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Update.
    Heres why.
    Dude. Bummer.
    I don't know what else to say.
    I feel your pain.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
  28. #467
    Arrkon's Avatar
    Oct 2010
    1,633
  29. #468
    slepy's Avatar
    No Audi but still here
    Sep 2009
    Sheffield
    908
    Oh noooo...
    I was waiting for the end result of your build and that is bad...
    Did you get the turbo new? From US or here?
    2007 Honda Civic Type R daily. Soon for sale
    1999 Audi A4 1.8TQS - track car project
  30. #469
    Aug 2010
    2,866
    Just when I thought you had hit the nail on the head with the build.
    Hope you get everything sorted mate.
  31. #470
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
  32. #471
    Apr 2004
    12,354
    I have taken the head apart.. the valve has seen better days.
    Sadly the seat is marked, and the throat of the port had melted valve stuck to it, i dremeled that off and was left with this un useable seat.
    So that's off having a new seat fitted, fortunately that's only £40 which is cheaper than a new head.
    I am aiming to clean and inspect all of the exhaust valves while she is apart to check for cracks and the likes.
    While we are on the subject of cracks, the manifold has seen better days. This will have to be welded for now as i cannot afford to replace that just now
    It's surprising how many parts make up the head assy.
    Old CHRA
    Turbo in bits
    And the new CHRA, It was ordered correctly but there is some issue that the part number makes it larger than the old one. Sadly i don't have both handy till sunday so will see whats what then. If it's wrong i am sure it can be fixed/replaced etc.
  33. #472
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,652
    Mark,
    I assume the A/S3 1.8T mani is different to the A4s cause the A3s engine is transverse?
    Its only cause a couple of the A/S3 boys (Welly and Westy off the top of my head) might have some spare mani's.
    Just a thought to save you from having a cracked/welded unit on.
  34. #473
    "Stick a V8 in it!"
    14,900
    yeh its positioned differently (turbo flange is infront of cyl 3 rather than 2) and the flange is also 180degrees out, so the turbo points the other way.
    K04 (s3) manifold is different again, mounting the turbo even higher and further over.
  35. #474
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,652
    O well the thought was there.
  36. #475
    Apr 2004
    12,354
    I'll get it welded for now and will get a new one when i can afford it in a month or so, priority is getting her working reliably as fast and as reasonably priced as possible.
    Going to have a play tomorrow and see what we can get done.
    Non of this would be possible without Bill @ Badger 5 or my friends and family for their support
  37. #476
    gmx
    Feb 2009
    Sydney
    132
    yup the CHRA from the eliminator is actually a GT2560RS (28r) variant.
  38. #477
    Apr 2004
    12,354
    NOt much progress.
    A new clutch is needed as the old one cannot take it when she comes up on boost,so I am on actuator only ATM
    1 bar actuator, but boost creep to 1.2 after 6k. Not sure how to fix that,
    Just before the clutch was giving issues i was seeing 2 bar due to the creep, that's going to cause an issue, I am not sure how i am going to combat that just now.
    I am seeing 186 GS at this 1.2 bar actuator, so not mega shabby.
  39. #478
    Apr 2004
    12,354
    I have attacked the arse end to stop the rear steering by polybushing the wishbones.
    I have been chasing an annoying rattly noise and added to the fact its engine out to drop the sump it made sense to pull the engine to have a peak and change the clutch/ flywheel while i am in there.
    I dropped the engine and box together with the aim of also nailing a 2wd box in for tuning purposes.
    I am having to strip the old engine to have the rods and head from it.
    The old pistons and rods pictured here comparing them to oem rods.
    Found the cause of the noise.
    Cylinder 3 shell is quite worn, the journal has picked up, good job I am changing the engine completely bar the head and rods.
    Heat from the rattly shell has left a heat mark on the rod.
    I am 99% the rod will be fine so it's going back in with new shells and rings
    Note the notch and orientation of the shells, also this is an undamaged rod, you can see the difference
    Piston rings compressed to go back in
    New pump as a matter of course.
    This is where i left here this evening.
    Tomorrow the wastegate will hopefully be ported by Bill ready for the head to be refitted and turbo bolted on.
    Then the SMFW and 240mm clutch and 2wd box, sounds simple huh.
  40. #479
    Apr 2004
    12,354
    Not much progress but Bill checked the WG and we reset the preload once i had clocked the bracket to prevent it touching the ex manifold as it was very close. This left the adjustment too slack so i shortened the rod a few mm to allow more scope for adjustment if i ever need it
    Currently cracking open at 1 bar
    I came home and nailed the head on and the turbo for now, more tomorrow hoping to refit the engine Wednesday
  41. #480
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    Glad to see that you're making some good progress mate. Maybe one of us will get our car running properly at some point this year lol
  1. RS4 b5 progress thread
    By colicabcadam in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 10th December 2012, 11:25
  2. my avant progress thread
    By rawtor51 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th July 2012, 21:37
  3. my new s3 8l progress thread
    By s3schofield in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th October 2011, 17:23
  4. Progress Thread
    By MickM in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2010, 21:29
  5. Scroll SP51 thread
    By docurley in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st July 2008, 20:31
Tags for this Thread
