Hi all. I've been searching he forums on here but cant seem to find a guide to changing a thermostat on a '96 a4 1.8t aeb. Can anyone point me in the right direction? Cheers.
the stat sits in the housing that the bottom rad hose connects to on the engine.
Its basically a case of slide undernearth, remove rad hose and housing, fit new stat, refit housing then rad hose, fill with coolant and bleed from the heater hose.
