Volks AutosAH Fabrications
    Sep 2009
    15
    1.8T engine removal tips please
    I'm hoiking my engine out for some tlc and a clutch, front end is off which was easy enough but thought I would ask for any hints and tips before tackling turbo and lifting.
    I have searched the net and found nothing on 1.8t removal...any steer would be appreciated, thanks.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    All i can think of that cause any problems are the 3 bolts from engine to bellhousing that reside behind the subframe. The engine needs to be lifted out of it's mounts to allow access to them
    Sep 2009
    15
    Helpful, thanks. when all else is free I lift the engine a little to access those last three bolts? Correct?
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    yep. it comes out pretty easy once everything is out the way. when you have the engine out might be worth removing the sump to clean out any sludge from the pick up. i was going to do mine but couldnt be arsed in the end.
    Sep 2009
    15
    Good stuff, is there a best way to disconnect the turbo/exhaust etc. I've done this sort of thing many times but not dealt with turbos much.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,316
    just unbolt the cat from the turbo.
    TD5 Land Rover Defender build
