Chris NottJMB Retrofits
Results 1 to 9 of 9
    Oct 2009
    Southampton
    7
    suspension confusion?
    Hi all. I've gotta '96 A4 1.8t sport and am looking at upgrading my suspension as my rear shocks are nearly dead. I'm steering clear of coilovers so looking at spring and damper kits. My budget is around 300-400 and i've got my eye on some Koni STR.T's but so far every kit i've looked at for 1996 a4 1.8t excludes the sport model...? Don't quite understand this as i will be changing the shocks and springs so why does it exclude my model? Sorry if i'm not making sense but surely someone has come across this? Thanks.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,074
    It's just that the sport sits 20mm lower than the normal model iirc. If you can stretch a little bit 400 should see you with some Bilstein dampers and allow another 140 for some Eibach springs and you're in business
    Life begins at 140mph
    www.passionford.com
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Thoroughly recommend Bilstein B6 and Eibach Pro Kit Springs like sport shocks but a bit firmer nice ride quality
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Oct 2009
    Southampton
    7
    So technically if a kit says it lowers say 40mm,on the sport it will lower just 20mm? Taking into account that the stock height is already 20mm lower than non sport models
    LPG Abuser & have VAGCOM
    Aug 2005
    Essex
    171
    Im doing a suspension swap at the mo, cos 1 of my rear springs on my QTS Avant is broken. Std sport audi shox are on back order (last saturday) in Germany, Std Srpings are stealer part only.
    GSF say the sport suspension is stealer part only but....
    Euro car parts and supplied me a pair of billes for about 100 each....
    I think I will sort the fronts out next year $$$$$$!
    See suspension threads......
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    I've not used the full koni kit, but i had a set of adjustable koni sport dampers on my old astra and found them pretty decent.
    They're now sold as "Koni SSK" though, the STRT ones wont be as good.
    Slightly out of your budget though.
    The other option might be to buy some eibach springs and a pair of koni sport/bilstein B6 rear dampers for now, then once you've saved up some more, you can buy the front dampers?
    TD5 Land Rover Defender build
    Oct 2009
    Southampton
    7
    I've read a few other posts regarding suspension. I've noticed a few people talk of Bilstein B8's. Would these be better than the B6's?
    "Stick a V8 in it!"
    15,320
    The only difference is they're shorter, afaik.
    So if your lowering your car stupidly, and need the extra travel, B8's are better.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,285
    The Bilstein's and Eibach are a great option, quite stiff but amazing handling.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
