EM TuningMonster Motorsport
    Sep 2009
    A, A
    32
    gearbox question
    Hi
    I am still looking for a better gearbox for my 1998 2.8q can any one tell me if any other gear box's will fit 2.6q? 1.8q?
    thanks.
    Sep 2009
    A, A
    32
    i have the chance of a 1999 2.8q box will this fit ?
    did they change after facelift?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    it'll probably be the same, check the gearbox code to be sure.
    TD5 Land Rover Defender build
    eightrac's Avatar
    Oct 2009
    Colonial Beach, VA
    13
    any O1A trans will work as long as its not for a s4 or tdi. I have a 1.8T trans behind my 2.8 right now.
    '97 2.8 QM
    DJJ (1.8T Trans) 5v swap in the near future.
    Oct 2007
    2,597
    2,6L tranny won't work, it's 4.11:1 while the 2,8L unit is a 3.89:1.
    eightrac's Avatar
    Oct 2009
    Colonial Beach, VA
    13
    Quote Originally Posted by Siena View Post
    Forgot about that one.
    The 1.8 trans has shorter 1st and 2nd gears and the 2.8L trans has a better 5th gear ratio for cruising.
    2.6, S4 and TDI use the 4.11 final drive ratios so they are out unless you get a matching final drive also.
    '97 2.8 QM
