Sky InsuranceEM Tuning
Thread: s4 engine idle
    Sep 2009
    Essex
    2,366
    s4 engine idle
    hi there
    if the engine is idling from cold, should the engine rock at all? a couple ive looked at so far had a slight wobble on idle. are they supposed to be dead still?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,318
    How you you mean slight wobble? Can you feel it thru the car?
    If you mean physically looking at the engine, i'd be very surprised if there wasnt some movement, it is afterall spinning huge lumps of metal round!
    TD5 Land Rover Defender build
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Perfectly normal for them to rock a bit as Aragorn says.
    Any engine with a V configuration will.
    Mo power, mo problems
    Sep 2009
    Essex
    2,366
    yup, thats what i meant, visually. one you could feel through the car would be a bit funky though.
    the one i saw lastnight had the very slightest wobble, nothing wrong there at all. i think it was tappets i coudl hear though when listening by the front wheel arches
    that normal too?
    Feb 2007
    Liverpool
    1,693
    Perfectly normal for them to tap a bit.
    It's when they tap a lot (ie: clearly audible from within the cabin) that you need to start worrying about cam wear!
