Chris NottJMB Retrofits
Results 1 to 7 of 7
    jcb
    Sep 2005
    uk
    4,077
    max %age tyre difference run on a quattro
    just found a screw 1 inch from the side wall in my almost new F1's!!
    pain in the ass as they cost me Ł100 each and the tyre monkey says he can't plu it to repair them.
    Ł25 and a 10 day turn around to get them done by a vulcaniser repair guy (no not star trek!!)
    still doesn't help me ....
    I have 245/40/18's all round
    I also have two spare 235/40/18 (total diameter is 1.23% out).
    am I asking for trouble running them temporarily whilst my tyre is being fixed?
    anyone run similar differences?
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    if you werent doing loads of miles i would think it would be ok. no lsd anyway.
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    Give me your brakes and you can use my spare 17s?
    Sounds like a plan to me!
    I would just run the 1% difference you have. If it only a couple of weeks I am sure it will be fine.
    A4 1.8T Quattro
    jcb
    Sep 2005
    uk
    4,077
    that is what I was thinking...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    If you calculate the diameter of both, you'll probably find the difference is similar to the difference between a new 235/40 and a nearly bald 235/40.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    probably.
    my worry is I will be nearly new 245 on the rear and part worn 235 on the front.
    likely to be closer to 2+% difference if I really think about it
    May 2008
    perth
    1,197
    just pump the 235's up to 80psi and put the 245 to 25psi. that should even it out.
