Badger5Chris Nott
Results 1 to 14 of 14
    IN 2 Deep's Avatar
    Hoonigan
    Oct 2009
    Lancashire, UK
    379
    FWD Driveshaft Flanges Needed!
    As the title suggest im after a pair of gearbox flanges that bolt to the inner CV of the driveshafts. I searched high and low for a set, Can anyone help me out? Or a knackered FWD gearbox will do!
    2000 Audi A4 B5 Quattro Sport - My build thread - Click
    2004 Volvo S60 D5 - Daily smoker & race car tow truck
    1993 Audi S2 ABY - Dead & buried
    1990 Audi Coupe 2.2E - Dead & buried
    jcb
    Sep 2005
    uk
    4,077
    what is wrong with them?
    IN 2 Deep's Avatar
    Hoonigan
    Oct 2009
    Lancashire, UK
    379
    Nothings wrong the the ones on the car, I want to fit the S4 hub carriers and driveshafts that are taking up space in my garage. Im also in negotiations for a really nice BBK for a B5 S4 but would need these flanges to complete the job as they are bigger. 108mm vs 100mm I think?
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    s4 hub carriers fitted on mine without swapping anything, have you checked outer cv dimensions
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    IN 2 Deep's Avatar
    Hoonigan
    Oct 2009
    Lancashire, UK
    379
    Really, If im honest I haven't checked a thing yet, I've only heard that the flanges will be needed. Is your car facelift?
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    mines a 99 1.8tqs, but if youve got the complete s4 driveshafts it would be easier to swap outer cv's if you had too
    kev
    90 eunos roadster
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    The upright for the S4 are 82mm bearings so the S4 shafts need to be used.
    I know Docurley used FWD flanges as i gave them to him and he fitted his RS4 uprights so he could use the Rs4 brakes
    IN 2 Deep's Avatar
    Hoonigan
    Oct 2009
    Lancashire, UK
    379
    I figure if I can get my hands on the flanges at least I have all options covered, nothing worse than spending a day wrenching and not being able to complete the job to then have to do it all again when you get the bits.
    Anyone get any suggestions where to look? I've exhausted all my contacts!
    jcb
    Sep 2005
    uk
    4,077
    leave the gearbox alone. you need new outers. the shafts themselves are exactly the same, hence the reason RS4/S4 outer and inner CV's will fit a 1.8tq shaft (same shaft dimensions!)
    I have B7 RS4 brakes on RS4 upright/hub carriers.
    I got a set of RS4 drive shafts, knocked the outer CV's off my shafts and the new shafts, swapped them over, bolted on the new uprights and plugged everything else in.
    pulling flanges out of the box is more ball ached than you need.
    just sold my half CV'd RS4 shafts as well! cost me next to nothing when you factor in selling the 1.8tqs outer CV's.
    outers only!
    Sep 2009
    A, A
    34
    i have some 98 quattro output flanges that knock into the front diff is this what your after?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    ^ Quattro ones are too small afaik, unless they're from an S4.
    JCB: surely it depends if you want the larger (stronger) inner CV joints? Maybe your method would be fine if your just running a stock motor, but if your sticking 400hp thru it, i'd suggest the larger joints are a nice to have, and Audi clearly thaught the same which is why the FWD and S4/RS4 has the larger flanges/CV's
    I have a set of FWD V6 flanges i pulled out of a FWD box before i scrapped it, open to offers if you want them.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    lots of things are nice to have.
    its a risk reward thing. I haven't heard of any gearbox flanges grenading at any power levels on these boxes. not without problems beforehand.
    shafts tend to snap off first, can show you lots of pics of broken driveshafts snapped off at the taper due to massive torque spikes.
    IN 2 Deep's Avatar
    Hoonigan
    Oct 2009
    Lancashire, UK
    379
    Well for me, I would prefer to run the S4 shafts. One because they are stronger and two I will eventually want to fit the 01E gearbox from the S4 so haivng the right shafts will save the ball ache later anyway.
    Aragorn, I will gladly relieve you of those flanges, PM with your price, I can collect as I only live in St Annes. I knew someone would be able to help me out! I've been looking for these for ages! Cheers fella
    jcb
    Sep 2005
    uk
    4,077
    shafts are the same, its the flanges and CV's that are different. but if you are swapping boxes then its a no brainer
