Chris NottBadger5
Thread: Engine Rebuild
    Apr 2009
    birmingham
    109
    Engine Rebuild
    Hello All
    just wondering when i should have my 1.8tqs engine rebulid as mine has done 153,500 miles and what sort of prices am i lookin at for a gd rebuild if it to much, im going to chose a different path to take
    cheers for ur help
    Gareth
    jcb
    Sep 2005
    uk
    4,077
    depends why you are getting it built?
    smoking becasue the rings are worn is the main reason, other than that these things will do more miles than you can. I have a Golf GTi on 225k..same block as this.
    if you just get new rings, hone and refit that is your cheapest option.
    could be as little as 300, its a head off,sump off job if done in the car (not ideal as the honing process showers the crank in ****e which needs to be washed off very carefully)
    but in my opinion if you are doing that get a seperate block (shagged timing belt etc), you can get them for free. do rings, bearings all pumps and seal and drop it in.
    It is cheaper to get work done out of the car than in and for your money you will get more done and have a fresher short block. you will obviuously have to have the old block removed and new one refitted (more cost).
    Apr 2009
    birmingham
    109
    mine just seem noisy or it could be me to be honest lol, still drive ok and pull ok
    Mar 2008
    144
    Might just be because it's getting colder and things tend to sound noisy.
    Is it OK when warm?
    Maybe a good oil change with quality oil might help.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    How do you mean noisey?
    Rattley? or a deeper sound?
    A good flush and oil change will work wonders. It's what i have just done on mine and the car sounded much better after
