Volks AutosEM Tuning
Results 1 to 10 of 10
    Jul 2009
    56
    Retracting Rear Caliper Pistons
    Hi Guys,
    I've just swapped the rear disks on my 2000 S4 avant. No problems getting the disk done but I really struggled to wind the pistons back in. I'm wondering if I'm missing something, or if the return is something that can go wrong.
    I managed the off side but it was really tight. After a short time with it moving we got the new pads in. The problem was the near side that was alot easier to move but didn't retract. In the end we put the old pads back, we didn't get the room to get the new ones in.
    I thought I'd post on here and see if some of you knowledgeable folk could tell me what my mate and I are missing, apart from mechanical talent obviously.
    Thanks.
    Mar 2007
    salford gtr manchester
    557
    the trick with these is to apply loads of preasure and turn very slowly i dont know why the speed that you turn the piston matters but it does i have found this a few times very slowly is the answer
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,372
    I have also found pushing the piston out a bit more and a liberal spray of LUBE under the dust seal can help too. You will need to be careful you do not go too far and push the piston out, or too far to get the windy tool in place.
    Jul 2009
    56
    So I need to push the piston in and twist it at the same time. Whats the best way of achieving that?
    Thanks for all your help and advice guys
    Apr 2004
    12,372
    Have you not got a piston retracting tool?
    thats what you need
    Jul 2009
    56
    Ah I need a special tool. I used a piece of bar with 2 blobs of weld on, ground to engage the cut outs on the piston. My mate turned that while I had some big grips trying to force the piston in.
    That worked on the off side but only limited success on the near side. The new pads would fit but only when lightly hammered in and that was no good because it would all bind up. We just couldn't get that last couple of mill.
    what sort of money is the correct tool? You called it a windy tool, its powered by compressed air?
    Apr 2004
    12,372
    What you have will probably work with some ingenious G clampage and twist. Its a more pressure, less turn that seems to work.
    I think it's just called a piston retracting tool, it has a tommy bar and a blank metal plate kinda like a pad that has a slot in it to allow the cetre bit to slot in to allow it tp apply pressure to the piston while the tommy bar bit is turned, around 18 iirc. Worth its weight in platinum IMHO
    Sep 2009
    A, A
    30
    I used a small g-clamp and a pair of mole grips to turn the pad on the g-clamp worked just!
    Oct 2006
    88
    try i as did , i could not retract one of mine on the car.
    undid brake pipe and placed in vice - job done.
    lots of effort was needed, no way i would have doen it with the tools i had to hand on the car.
    CraigG's Avatar
    May 2008
    188
    Wouldnt jamming it in a vice like that damage the handbrake mechanism?
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
