Badger5Volks Autos
    Mar 2009
    How to remove steering wheel?
    Hi I have a 1997 R reg A4 TDi and I was wondering how you remove the steering wheel in ordere to change the wiper stalk switch?
    I have disconnected the battery and removed as much associated plastic trim as I can and there appears to be two bolts in the reverse of the steering wheel itself which are recessed out of view. I'm not sure if they can be removed with an alan key or a torx key but neither seem to work they just seem to be stuck on? These may already be somewhat rounded off?
    Is there any other things to be aware of so I don't damage the airbags/immobiliser?
    If anyone could help I'd really appreciate it, cheers.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    should be a torx key, dont you have a small mirror to shine behind it, to see if rounded off? it should be a T30
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    jcb
    Sep 2005
    uk
    4,077
    don't have your keys in the ignition when you do it.
    people say disconnect the battery to make safe the airbag...I didn't. no keys no airbag.
    two small torx scres on e on each side behind centre spar of wheel, one large on in centre of wheel behind airbag. unlpug horm and bag depending on car it may be one or two spade connectors. air bag connector has a lock on plug in the centre at the back
    you will need a breaker bar or longer ratchet to undo the centre 12 point splined bolt that holds it on. F Tight!
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    dont forget the thread lock for the reinstall, oh and the early ones is like a 22mm nut instead of the spline drive, mark it up to before you pull it off
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
