Monster MotorsportVolks Autos
    Sep 2009
    Essex
    2,366
    pre/post facelift mechanical changes?
    hi there
    what mechanical differences are there pre and post face lift on an S4? i know what the cosmetic ones are and im not really interested in those
    if i get a pre face lift car, what am i missing out on hardware wise?
    Jul 2007
    London
    3,246
    Dont think they are any different, the only difference i can see is the early ones might have rubber bushed track rod ends but the facelift ones will have one piece track rod ends and maybe stiffer suspenssion.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    the later S4 came with [ESP] traction control button
    just incase you havent seen this for other info in buying
    http://www.audi-sport.net/vb/downloa...yers_Guide.pdf
    there are some mechanical differences
    other differences
    GOOD LUCK IN YOUR HUNT!
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    The pre-facelift S4's had exhaust manifolds prone to failure which resulted in shards of metal being fed into the the turbos. The facelift S4's used better manifolds (same as the RS4).
    The last run of the S4's (late 2000) used a Hitachi MAF and a modified inlet manifold which got rid of the troublesome F-hose.
    Facelift cars had vented rear brake discs as well as better calipers.
    Can't think of any other significant mechanical changes.
    Mo power, mo problems
    Sep 2009
    Essex
    2,366
    ah, this one has samco f hoses and throttle body hose
    it already has the later manifold.
    looking promising...
