Volks AutosAH Fabrications
Results 1 to 14 of 14
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    Oil catch tank/can..
    Can anybody recommend an oil catch can?
    Any info would be greatly received.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    A guy over on AudiSRS made one himself out of some basic plumbing parts from B&Q. Works better than a couple of the branded items which he'd tried previously.
    Mo power, mo problems
    Oct 2007
    UK - Midlands
    2,223
    Nice one.. cheers mate.
    jcb
    Sep 2005
    uk
    4,070
    I am making mine. stainless thermos flask...
    pretty easy, key thing is to make sure the contains has a good amount of material in it, wire wool, lathe swarf etc.
    are you planning on venting to atmosphere or back into inlet?
    I need to tap the cam cover on mine, some already have it.
    Oct 2007
    UK - Midlands
    2,223
    Originally I was planning on just venting to atmosphere but don't know whether I could put up with the warm oily smell for long.
    I have also heard of others having running issues if the vented air doesn't recirculate into the system?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    be hard core, run a pipe to the floor,lol I did that with my Very old Mk2 ecsort,lol
    Should have seen the undserside of the car when i blew the engine, how it rusted through all that oil, i will never know
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by Byzan A4 View Post
    LOL..
    I had a MK1 Polo with a breather filter on and the smell was strong.. might give the A4 that racer feel though lol.
    jcb
    Sep 2005
    uk
    4,070
    yeah, it does stink. it also affects some of the pressure sensors or vacuum sources. not sure which or where but it would make sense.
    Apr 2004
    12,355
    Not oil pressure, vacuum for sure as that relys on it being a sealed system with non return valves in place etc
    Sep 2009
    Essex
    2,366
    the underside is about the only part of my golf that i dont worry about rust now
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    Oct 2007
    UK - Midlands
    2,223
    Cheers docurley
    gaz71's Avatar
    1.8T Quattro Sport AJL
    Jul 2009
    Torbay
    287
    Found this, thought it might be useful;
    http://khguan.fotopic.net/c976027.html
    jcb
    Sep 2005
    uk
    4,070
    interesting but IMO not big enough.
    ideally you want a much larger volume around 500cc / half a litre with plenty of air between the condenser material internally.
    the vapour entering needs plenty of space to condense and remove the max amount of liquid (oil and water) before re-entering the inlet tract.
    The larger volume creates a pressures drop, cooling and slowing the vapour down.
    that petrol filter will collect some but nothing like the amount it should be collecting.
