Badger5Sky Insurance
Results 1 to 13 of 13
    Oct 2009
    village life just outside manchester
    21
    wastegate chatter
    my car is totally standard what do i need to get wastegate chatter any pictures of yours would be great
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    bypass the dv off and fit a cone filter or cheese hole the original airbox but your titchy little turbo will prob break after a couple of days if not hours
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,506
    You will need to upgrade to a big turbo and run it without a DV then you will get compressor stall which is sometimes confused with wastgate chatter. The Std turbo in your car is not strong enough to allow stall, the shaft will snap
    So i imagine if you spend around 5 k on the conversion you will get what you seek
    Oct 2009
    21
    ok then what if i fitted a dump valve or should i just leave it alone?
    Apr 2004
    12,506
    You need a splitter valve as the ECU on the 1.8t is programmed to have the air recirculated, and without it, the ECU will mess with fueling. The splitter valve feeds just enough air back into the system to make it work correctly and then enough to atmoshpere to make a woosh assuming thats what you want
    Oct 2009
    21
    Sep 2009
    Essex
    2,366
    wastegates dont chatter, in fact, they dont make any noise at all.
    what most people call "wastegate chatter" is actually compressor surge. to achive that, get rid of your "dump valve" all together and youll have plenty of compressor surge.
    failing that, get an atmospheric DV (bad idea) or keep the normal recirculating one and fit a cone filter, youll hear it more then, but cone filters are a bad idea, so you lose either way just for a bit of noise. you could just sit indoors and watch the fast and the furious for your fix though if you dont want to make your car slower
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    my wastegate chatters, but thats because its half broken and the pennys about to fall off :P
    As matt and mark say theres no such thing as wastegate chatter, its called compressor stall, and while it might work, i dont think the K03 would handle it for long. If you want to try it, then remove the existing recirc valve and block off the pipes, how long the turbo lasts though i couldnt guess.
    TD5 Land Rover Defender build
    Sep 2009
    Essex
    2,366
    a friend of mine loved the sound of compressor surge, so much, that she had someone get rid of her dv all together
    maybe a year later it has been remapped, it chirps even louder (does sound cool) but the life expectancy of the turbo cannot be good when that air comes through the compressor the wrong way haha
    as for your wastegate... bad times!!
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    I fitted a k+n 57i induction kit to my standard (apart from a re-map) 1.8t around 18 months ago and havn't had any problems at all and get a nice 'ptish' sound from it!! No noticable losses in power or heat soak or anything
    White B5 1.8 turbo sport
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,074
    I feel a spot for my Fiesta chatter clips again
    http://www.youtube.com/watch?v=baUEBAKw5vQ
    http://www.youtube.com/watch?v=ts6_ZCjtLUQ
    As above though it's nothing to do with the wastegate. Audi's won't like chatter as teh system is MAF based and it will louse up the fueling and I have also been advised the K03 turbo's are quite a bit more brittle than the Garret item I ran in the Fiesta
    Life begins at 140mph
    www.passionford.com
    Sep 2009
    Essex
    2,366
    Quote Originally Posted by floyd 1.8 turbo View Post
    cool, how did you actually test for gains/losses then?
    Apr 2008
    Bracknell, Berks
    630
    I didn't, thats why i said no NOTICABLE losses. Still seems the same as the day i bought it nearly two years ago. I should imagine there is a small power loss but nothing of any significance
