EM TuningAH Fabrications
Results 1 to 27 of 27
Thread: i need help
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    i need help
    got my ebay vagcom lead today with drivers and the disk off ebay, all installed and drivers too so thought id try it out
    tested and saved on port COM3 but it keeps saying no response to controller when i go into things, i tryed to go into ENGINE but kept sayin no response?????
    any ideas peeps
    Jun 2003
    World of my own
    9,813
    If it's a freebie version of the software then it doesn't let you do much, just do a scan, you need to pay for a registration key to unlock it to get full access to everything.
    Alex Turner
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Ignition was on yes?
    Jul 2006
    1,562
    It means you have no engine.
    Have a look under the bonnet (at the front), and you'll probably see the pedals you've been using.
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    If the lead has a power light then check it's illuminated as I had a faulty lead which gave the same error 'no response'.
    Jul 2006
    1,562
    Must admit, I couldn't get on with my Ebay cheapy either. I gave it to a neighbour who has a Passat and bought a genuine lead. Trouble-free ever since.
    Oct 2007
    UK - Midlands
    2,223
    Think S4s are just made to cost you money.. they even reject cheap kit in protest!
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    What version of Vagcom are you using?
    Have you installed the serial-usb emulator drivers?
    Have you tried going into any other modules or just Engine?
    Mo power, mo problems
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    You need to check which serial port windows is recognising the adaptor on, and if its silly, move it to a more sensible one.
    My laptop usually allocates it COM13 or something if i forget to put it in the usual com port.
    If you hold down the windows key and press break (or right click my computer and choose properties), Then choose device manager, scroll down to ports and open it, it should tell you in there.
    TD5 Land Rover Defender build
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    settings force dumb mode , works for me
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    i keep hearing about tis device manager but when i go into it i cant see PORTS in there, the usual stuff but that about it, ive clicked on the USB one and brought up the properties of the cable im using but i cant/dot know how to change ports, in vagcom(409-1) im on COM3 when i tested and saved but it not happening for me
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Grant mate, When we got back from Audi Inter's i got on ebay and bought myself a cable for my b6 ....I'm now S..ting myself becouse i have no clue when it come's
    to this sort of stuff. Which seller did you buy your's from..
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    got mine from A+E trading ltd under the seller user id gps-ppc
    12.99 free shipping
    im just thought it was plug in and go to be honest mate, why is evry thing confusin lol i need to get more on the laptop, im 24 and feel 50 when im sitting at one of these
    rob v6's Avatar
    Learning the VAG way
    Oct 2009
    Dudley
    161
    Quote Originally Posted by S4twiggy View Post
    12.99 free shipping
    you mean this one
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    wye eye lad that there be the one
    "Stick a V8 in it!"
    15,389
    Right, i've taken some screenshots for you:
    Open the device manager:
    Then find the ports item:
    Open it, and select the USB Serial controller. You'll see it says (COM4) in my example, if yours is on 1,2,3 or 4 then all you need to do is select the same number from inside vagcom, and it should work.
    If not you need to change the port onto one that vagcom can see. To do that right click the port and then choose properties:
    "Stick a V8 in it!"
    15,389
    Once the properties panel opens, choose Port settings, then click advanced:
    Then open the com port number dropdown and choose a port between 1 and 4. Ignore it if it says its in use, windows does that for some random reason:
    It will give you this message, say yes:
    Now you just need to select the same port from within vagcom.
    Also note though, that you'll probably have to start vagcom as an administrator on vista/7
    To do that, right click the shortcut, and choose run as administrator:
    See how that goes...
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    yep done that and changed port to COM1 but it dont work in vagcom on COM1 butif i test it on COM3 in vagcom it says port ok and interface found???????????
    "Stick a V8 in it!"
    15,389
    Hmm, if its on com1 in device manager you really should select com1 in vagcom. It also wont respond unless the lead is connected to the car with the ignition on (ie dash lit up), as only the USB to serial adaptor gets powered from the PC, the serial interface itself gets powered from the car.
    Maybe try unplugging it and replugging it after you've forced the com port just to make sure its defo on com1, and make sure you start it as administrator, or the OS might not allow the program to access the com ports.
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    rite im off in the car lol
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    seriously all i did is select dumb mode and click usb , im running vista so had to load in admin mode as xp to make vag com work at the time
    "Stick a V8 in it!"
    15,389
    If you have an ebay lead, you cant use "usb" mode, as that only works with the real vagcom leads.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    I have an ebay lead and yes i use usb mode but have to click on force dumb mode
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    all sort now, i had to change com ports in device mnager, works fine now, shall be gettn the real rostech one soon as mine doesnt bring up the names of the codes due to it being shareware or summin.
    does the rosstech come with the licens and the lead?????
    Sep 2009
    Essex
    2,366
    hes been gone a while, wonder if it was good news....
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    Quote Originally Posted by Matt82 View Post
  28. #27
    Sep 2009
    Essex
    2,366
    you plugged your car into the computer... what did the computer tell you?
