what bhp are the standard injectors good for on a 2000 plate quatro AJL engine gode and whats the max power the ko3s turbo is good for
and if we use this:
and convert 259cc/min into 24.64lb/hr, we get:
24.64 * 0.8 / 0.5 = 39.4 hp per injector at 80% duty cycle.
if we go up to 100% duty:
24.64 * 1 / 0.5 = 49.28 hp per injector
That formula says they shouldnt even manage 200hp, so if they are making 230hp, they'll be running absolutely flat out and way beyond spec.
I presume the discrepancy is due to the fuel pressure increasing when under boost.
yeh it really makes no sense in your case Lee.
I can only imagine that its either because the fuel pressure climbs with the boost pressure, so at 23psi your actually pushing 5.5bar of fuel pressure (although this would normally be offset by the pressure in the inlet) or its leaning out at the top end.
Either that or chimped uk jammed the fuel pressure regulator in a vice and your now running 5 bar static
I think they just worked their special magic in the purple ones case.. will be commencing engine work ASAP so the stock injectors will be replaced with something much more capable
Nah i can't see it being lean at top end due to the puff of black she puts out when accelerating . I was there the whole time they were tinkering, i know they didnt 'modify' the FPR to 5 bar,lol
You must have gone to the toilet at some point.. they just gave the FPR a few taps with a hammer! Job done! lol
Seriously though Yeah.. Doesn't seem to be lean at full boost. Obviously it's on the limit now though.
well for us it's true anyway. I ams ure thats what Ed was basing his question on.
Even the 1.8 NA has a 4 bar. PS got the kit this very min, cheers
The standard injectors are rated at 225cc/min, pretty poor really.
If you really want more, then i'd look at a set of "yellow-top" injectors from a Vauxhall C20LET.
They are bosch 0 280 150 420 and flow around 310cc/min
Good for 280-300hp i suspect, and theres some on ebay for 20-40quid.
Or you can look for a set of "Saab reds"
Bosch number 0280150431 from Saab 9000 and they will do 350cc/min, some of them on ebay too, bit more expensive though.
Nope, can't see them being any cheaper than £50 each. I have aquired a set of LETs and going to get them cleaned, will still cost under £60 deliverd, bargain i say
