EM TuningMonster Motorsport
Results 1 to 7 of 7
    Aug 2009
    33
    B5 & B6 2.5V6 TDI differences?
    What are the differences in the two engine wise as the B5 has 150bhp and the B6 180...
    Does anyone know?
    Jul 2007
    London
    3,080
    Different nozzles, turbocharger and map/ECU. Base engine is the same. The AFN/AKN goes to 180Bhp with a simple tunning chip. The AKE goes to 210Bhp with similar chips/remap. There are v6 tdi tunned in europe with over 260Bhp and on stock pumps. Wach this space as i am slowly building me a4 quattro to about 250Bhp with a big turbo, iveco nozzles and a PSI/Steinbauer chip. Not much stuff available for the v6 tdi i'm afraid !
    Aug 2009
    33
    Mines a AGA/AJG...
    What bigger turbo will go on and you say Iveco nozzles?
    Please, do tell
    Jul 2007
    London
    3,080
    Merc 3.2 CDI or bmw 3.0D Garrett GTV 2260 will fit with a bit of modding/welding, ford/iveco 2.8L+ diesel nozzles will fit but check the part numbers as some have a different spray pattern. Any bigger than standard will flow more fuel. Also you can upgrade to later cam rollers cyl. heads-if you go mad with the tunning- from BDG engine code. Less likely to eat the camshafts or loose rocker arms inside the cylinder head...
    Aug 2009
    33
    This is great news!
    What are the part numbers of the injectors I will need?
    The turbo shouldn't be a problem though TBH...
    Any thoughts on my engine?
    Jul 2007
    London
    3,080
    Its ok but i would look for an AKE lump if i were you or at least get a quattro as you wont have problems putting the power on the road ! I have a lightly fettled a6 V6 tdi FWD and it spins the wheels in 4th gear if i am giving it the beans ! The a4 v6 tdi quattro puts the power on the road with no drama though...but the a6 handles much better !
    Aug 2009
    33
    Thanks, I have a Quattro anyway but can feel what your saying.
    These part numbers for the Iveco injectors... Any in particular?
