Volks AutosAH Fabrications
Thread: gearbox noise
    Sep 2009
    A, A
    30
    gearbox noise
    hi
    i have replaced the gerabox in my 1998 quattro and first gear is noisey could this have anything to do with incorrect linkage alignment, i personally do not think so but the guy i brought it off says it was fine for him?
    Mar 2007
    salford gtr manchester
    556
    is it like a rasping / fast ticking noise when you take up drive in first then disapears when you press the clutch and select second if so you have a chipped tooth on first gear was it a recon box or second hand there is plenty of info on the net about this problem
    Sep 2009
    A, A
    30
    it was a second hand box and yes it's like a rasping sound, the pitch gets higher as you speed up. i now have two busted gearbox's could i replace first gear (lay shaft)?
    Mar 2007
    556
    mine is the same its a 2.8 quattro a6 theres a lad on audiworld recons hes been running around with it like this for the past 4 years. not too sure if its fixable but i would be very interested to find out any more info would be very welcome
    Jul 2009
    Mine makes same noise in first,, been like it two years since buying the car,, now got 185K on clock and still ok... Will fix it when I no longerr have first gear...LOL
    Audi A4 2.8 30V Quattro.....
