JMB RetrofitsEM Tuning
Results 1 to 26 of 26
    Sep 2009
    76
    I'm buying these in 2 hours! Help!
    Do they look as if they'll fit on my 1996 a4 b5 1.8 standard manual?
    And could anyone hazard a guess as to what make they are?
    Oct 2007
    2,597
    They'll certainly fit your car, yes.
    Not sure what height it'll be when fitted though, without knowing spring rates and make.
    Sep 2009
    76
    they are off a 1.8 turbo, will it be the same fitting?
    jcb
    Sep 2005
    uk
    4,077
    yes, but why would you buy them if you don;t know what they are?
    suspension is not a part you want to gamble on, even if they are 50!
    Sep 2009
    76
    I've bought them now anyway. couldn't get access to the site in my time of need so i took a gamble and paid 95 all in
    Is there a thread on here with a advice to fitting suspension? I've had a quick search but found nothing and i don't feel too confident as i've only had the car 2 weeks
    Sep 2009
    76
    Quote Originally Posted by jcb View Post
    I'll show you the pictures when it's done.
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    they will prob be like the sport struts you get standard so a little stiffer than what you have now.
    Sep 2009
    76
    ok cool, i dont mind that. Is it a straight forward job?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    the bottom of the rear damper looks odd to me....
    Shouldnt FWD A4 rears look like this:
    http://www.maxxtune.biz/ebay/bilder/SUAU003H.jpg
    Ie theres a bit sticking out the side of the bush...
    TD5 Land Rover Defender build
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    Yeah, you're right ours do have the 'bit sticking out' as in your pic.
    "Stick a V8 in it!"
    15,385
    maybe facelifts are different?
    Oct 2007
    UK - Midlands
    2,223
    Yeah possibly.. anybody?
    Sep 2009
    76
    mine's not a 4wd though, it's a standard 1.8
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by 9 below zero View Post
    It says F.W.D. (front wheel drive) mate.
    "Stick a V8 in it!"
    15,385
    ye, quattro rears are totally different, and have an Eye bush on both ends, rather than eye on the bottom and pin on the top.
    I just wonder if these are facelift rear shocks, but i've never seen a set so i'm not sure.
    Sep 2009
    76
    Oh no. Guess i'll find out the bad news when i try to fit them...
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Hmmm... can't remember seeing the extra 'sticky-outie' bit on the bottom of my coil-overs when I fitted them, and mine's only a 2wd Sport.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    "Stick a V8 in it!"
    15,385
    but yours IS a facelift...
    Facelift shocks are defo different, i just dunno if that particular bush is different...
    You still got the old shocks kicking around?
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Yeah, I've still got the old shocks/springs and top mounts in the garage at home, but not there to check them at the moment!
    PM me for more info
    Sep 2009
    76
    yeah these are off a 1998 facelift model and mines a 1996 FFS
    Sep 2009
    76
    is there a way to put that sticky out bit on the shocks i've bought?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Sometimes the bush(aka sticky out bit) comes seperate to the rest of the lower bush, certainley did with my coilies. the difference i remember from facelfit to non facelift is the topmounts are different for sure. I don't see why you would not be able to use the preface tops on them...
    Apr 2004
    12,523
    This is no more that a spacer for the lower bolt to be able to tighten the bush into the axle, so if you had some thick wall tubing the right length, ot even at a push some washers, i see no problem
    There is no such thing as a 1998 facelift model, so if they came from a 98 2wd they are a dirct fit, and probably come with the required spacer tbh. If they are from a later 2wd 1999 and on, i think its just the top mounts that differ, use your parts and you should be fine. But can't say for 100% without you actualy having the parts to hand to check
    Sep 2009
    76
    yeah i've just had a look on ebay and these three sets all cater for models 1995-2000 so i'll check the box for the sticky out bit
    http://cgi.ebay.co.uk/Audi-A4-1995-2...d=p3286.c0.m14
    http://cgi.ebay.co.uk/AUDI-A4-1-6-1-...d=p3286.c0.m14
    Jul 2007
    London
    3,250
    That's just a spacer to fill the gap between the shock and rear axle. I fitted a few sets of bilstein shocks to a few a4's pre and facelifts and they all had that bush there. Just remember to do one at a time so you put them in the right way otherwise you can bend the shaft...
    Sep 2009
    76
    ok, i've checked the box and there's no spacers there. Are there spacers on the original shocks that i can re-use on the new ones?
