Sky InsuranceJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
  1. #41
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    not that deep,its a scuff from a car bumper by the look of it.
  3. #42
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    you need to do something like this
    http://www.youtube.com/watch?v=rfsuCbxviDA
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
  4. #43
    May 2008
    perth
    1,197
    think ill give it a go with some wet/dry and some polish.
  5. #44
    Oct 2009
    63
    I've previously bought a H4 hi/lo (or however you say it, HID main beam, normal small bulb for other) HID kit, to my knowledge, all i need is the right bulbs to use this kit ......right? as ballasts are fine.
    what size/type do i need?
    cheers
  6. #45
    Apr 2009
    89
    great guide there - just fitted mine. 'like a glove' as you say.
    Quick question - in my kit there are 2 extra bags of cables - each with a 20w 10ohm resistor. What's that for? any ideas?
  7. #46
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,383
    at a guess, its to fool some kinda bulb monitoring system that everythings working ok?
    The A4 ones designed for HID's anyway, so it should be happy.
    TD5 Land Rover Defender build
  8. #47
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Extra cables with resistors...?
    Send them my way! My M3 needs them as the bulb check keeps throwing up bulb errors!
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
  9. #48
    jcb
    Sep 2005
    uk
    4,077
    yep, only required on flighty systems.
    mine pops a code every no wna dthen when I turn them off but it is instantaneous and goes as quick as it came.
    have some resistors here also if anyone wants them.
    thought I had a dead ballast last week, turned out to be a loose connector.
