Badger5Sky Insurance
Results 1 to 30 of 30
    marsie's Avatar
    Aug 2009
    sheffield'ish
    61
    S4 diverter valves
    i am starting to suspect the diverter valves are acting up on my 1999 S4.I have been offered different advice on what to replace them with? standard,upgrade or aftermaket(forge etc)
    As far as i know the ones fitted are standard,also am i as well off replacing the little valve thingy at the same time(n75??)
    Any advice and rough costs would be brill
    Ta
    Paul
    1999 Audi S4 2.7 bi-turbo*SOLD*
    1997 landrover defender 100" winch challenge truck
    1998 Range rover 4.6 autobiography
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    The most common recommended OE swap would be to replace them with 710N valves from a TT or S3.
    They're about 20-25 new.
    Or you could fit something like the Forge 007 recirc, but i dont see the point personally.
    TD5 Land Rover Defender build
    Sep 2009
    Essex
    2,366
    the forge one isnt that smart from what ive seen. a friend of mine had a 20vt, the dv failed giving fantastic compressor surge noises.
    the forge item went on and in certain conditions it still got that "doh" sound when you came off the throttle
    the OE one didnt allow any noises at all
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    I like the Forge DV.. the build quality is top notch and it's tuneable for increased/decreased boost pressure which is handy. Only downside is the cost!
    Fraser's Avatar
    Aug 2003
    the north
    586
    the forge ones are serviceable as well so the long term outlay should be less
    Jul 2006
    1,562
    I chewed this over for a while and decided to go for the 710N's.
    The cost, the servicing and the noise put me off the Forge ones.
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    i had the s3 one's fitted by the tuner before my remap and have had no issues with them at all
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    S3 valves = TT 225 valves... right?
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    yeah i would have thought so
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    That's what I've got on my 1.8T... no problems with it at all.
    PM me for more info
    RmcMills's Avatar
    Apr 2009
    34
    I also suspect my valves are playing up too, However when i had a look at them they were already the forge ones. I had a s3 one lying around and felt the spring pressure was far far higher on that than the forge ones. I havent a clue how long the forge ones have been on, Can they loose their springyness and become ineffective?
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    yeah metal fatigue and age could cause them to slacken up a bit compared to new
    Oct 2007
    UK - Midlands
    2,223
    ..best to try and keep them well greased too.
    marsie's Avatar
    Aug 2009
    sheffield'ish
    61
    Thanks for the info guys,think i will go for the 710n's.Is there any benefit to fitting these over the standard S4 valves?
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    just the cost i think
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,087
    I've got no complaints with my Forge 007 on my 1.8T. Been good as gold since fitted. Bargain at 15 as well
    Life begins at 140mph
    www.passionford.com
    "Stick a V8 in it!"
    15,374
    marsie: they have stronger internals and a bigger spring, ideal if your uping the power.
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    i dont know wot the difference is with the 710A and 710N can someone eloborate as i have one 710A which came with the car out the factory and one 710N which was put on when i had my lamda sensor done. should i get another 710N for the other side?
    Jun 2009
    173
    Personally i would, just to balance things out especially with one being new.
    marsie's Avatar
    Aug 2009
    sheffield'ish
    61
    Cheers,gunna contact TPS tomorow for prices,think i may change the n75 valve also at the same time
    Paul
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    i mite do that too mate, new DV and N75 all for 60......sorted
    Jul 2006
    1,562
    I've done the MAF and the DV's since I've had the car, but I haven't renewed the N75 yet.
    Where's cheapest for them at the moment?
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    dont know if this is of any use to anyone http://www.s4biturbo.com/art-dvtests.php
    there are other good articles on there
    marsie's Avatar
    Aug 2009
    sheffield'ish
    61
    has anyone got the correct part numbers for the 710n valves and n75? the guy at TPS had no idea what i was talking about and kept asking for my chassis number even though i explaned that it wasnt a standard fit on my car
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    06A 145 710N
    There's a guy on eBay selling them for 31 each.
    Why are you changing the N75? If it ain't broke, don't fix it!
    Mo power, mo problems
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    i think they're about the same from audi too, i'm sure thats where mine came from when they were changed
  28. #27
    Jul 2006
    1,562
    Quote Originally Posted by Blue_Thunder View Post
    Moi?
    Are these an item that either works or doesn't work then (unlike a slowly fatiguing MAF)?
    Nothing shows up on the Rosstech.
  29. #28
    Feb 2007
    Liverpool
    1,693
    If an N75 is failing you'll know about it. You get erratic boost and can feel the spikes and flat spots when you are at WOT. They will quite often show an 'Overboosting' DTC on Vagcom if they are faulty.
    You'll probably find most of the VAG turbo cars are still running their original N75's with no problems.
    I got a new one when trying to fault find on my car. The only difference it made was to the contents of my wallet. Would only look to changing the N75 if you have noticeable boost issues and you have ruled out all of 'the usual suspects'.
  30. #29
    Mar 2009
    Somerset, UK
    148
    Quote Originally Posted by Matt82 View Post
    I can 2nd that, i fitted one to my old chipped 1.8T Passat and wasn't impressed at all as the extra 50 horses couldnt really be felt from the chip, i then tried it with my old stock DV and the difference was imense.
    I actually built a test rig to see if the forge was holding boost and i found it to be leaking like a sieve, where as the standard one didnt leak at all, i even showed the tuner that did my chip and who supplied the forge dv, i also tried a few more forge dv's he had and none of them sealed properly, he was quite shocked and promptly gave me a refund, he also supplied my findings to forge but they weren't really interested, all they did was send me a couple of different springs and a free keyring and stickers.
    In the end i just fitted a new 225bhp TT standard DV and never had a problem, it happily held 18psi boost all day long.
  31. #30
    Nez
    Dec 2008
    London
    595
    I have the Forge DV on my S4 and I am very happy with it
    (Audi S4 351.9 PS, 603 Nm, MRC Custom Remap XS Power DP's, Cat Back Exhaust, Forge DV, RS4 Intercoolers, RS4 Breaks and Induction kit)
    Traffic Exchange Site http://www.limehits4u.com/
