AH FabricationsChris Nott
Results 1 to 18 of 18
    Sep 2009
    Our 2.5 Tdi broke..does my mechanic know what he's doing?
    Evening All!
    We own a '99 141k mile 2.5 Tdi Avant Quattro. Recently it had started cutting out right after starting and then the central locking failed (probably unrelated). Then on its way back from a 140k service at our local specialist it broke down having cut out at a cross roads and has failed to start since.
    After suggesting the tank fuel pump, fitting a new one and the car no longer starting. My mechanic now "thinks" it's the fuel injector pump because no fuel is being "sucked" from the tank when the engine is being turned over. Since this is a 1000 part I'm a tad apprehensive to just go.. yeah slap a new one on!
    Soooo audi experts could it be the fuel injector pump? What is the tank pump supposed to be doing? I thought that was the low pressure pump making sure that there was sufficient fuel engine side....
    Anyway a few questions I'd be really glad for your help;
    Is the immobilser attached to either of the fuel pumps?
    Can I isolate the problem to the fuel injector pump?
    How can I tell if the tank pump is working okay?
    I hear about a fuel pump relay.. could that be the problem?
    I'd be really grateful if anyone could help!
    Many thanks in advance!!!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Common fault sadly. The injector pump is expensive and good used ones are rare.People are known to scrap their cars for needing the pump done.
    Sorry to be the bearer of the bad news
    Jan 2004
    York
    1,654
    Has the ecu been scanned for faults using something like Vagcom ?
    MY15 8V S3 Sportback with options
    Sep 2009
    Quote Originally Posted by auroan View Post
    The ECU has been scanned but I can't remember the exact codes, one relating to the immobiliser (I think) and one relating to an engine mount. I'll get the exact codes tomorrow.
    Hopefully more info tomorrow!
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    yes sounds correct, but i managed to get mine rebuilt and refitted for just over 800 so shop around
    pbasher.com are a reputable supplier or if you live anywhere near stoke i can get number for garage i used
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    If the pump is the problem try pump recon at
    http://www.dieselbob.co.uk/index.asp
    http://www.dieselpumprepairs.com/#
    http://www.mickogdendiesels.co.uk/
    Diesel Bob recently recommended elsewhere. There are others. Cheaper than a new pump.
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Jan 2004
    York
    1,654
    Hang on !!!! you said there was a error code about the immobiliser. Well if there is a fault with that you'll get the exact symptons you describe.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    is your car a b5 or b6? b6 pump is linked to immobiliser
    kev
    90 eunos roadster
    Jan 2004
    York
    1,654
    99 so a B5
    Sep 2009
    It's a 2000 on a V Reg. Looks a bit like this...
    I was wondering whether the immobiliser was attached to the fuel pump especially after the central locking went the week before but if the fuel pump isn't attached to the immobiliser then I guess that error code (if I'm remembering correctly) isn't related...more info tomorrow guys thanks for the thoughts so far! If you can think of anyway I can isolate the fuel pump do say!
    Jan 2004
    York
    1,654
    If you have a immo fault; your motor will start then immediately stop just as you have said in a previous post. All the immo will do if it fails, is stop the main injector pump anyway so I'd investiage the immo error code first if it was me. Before I even went anywhere near the fuel system.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    99 so a B5
    missed that bit sorry
    im guessing you would of mentioned if immo warning light was flashing when it was cutting out
    kev
    90 eunos roadster
    Jan 2004
    York
    1,654
    Quote Originally Posted by olds_kool View Post
    Good point on the immo light, although do they always come on for all immo faults ?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    I suspect that if it IS an immo issue, its not starting after the pump change as the pump wont be running for long enough to reprime the fuel system.
    Does sound immo related, and if theres a fault for that, i'd go there first.
    Where abouts are you based?
    TD5 Land Rover Defender build
    Jul 2007
    London
    3,234
    Talking
    Hi there, if there is a IMMO problem, the warning lamp will flash and the car will start but almost immediatelly stop. If there are no other faults logged in i would ask someone with Vag-com/VCDS do a log and check if the pump controller is getting power from the ECU(in basic settings block 15/16 - dont remember wich one but you will see it !). It should be about 12V . If there is power to the pump's controller, i would look elsewhere, if there is no reading/low voltage i would have the pump refurbished by dieselbob. Just to save you some time, the VP44 are notoriously rubbish at bleeding and the tank pump is there just to prime the main chaimber in the tank so i would get someone to tow you round the block with a towbar while the engine is spinning in 2nd in gear(like when you wanna tow start-it). Thats the best way to bleed said pumps. If the car starts then its air ingress if it does not chances are the pump is knackered. You could also try a squirt of Easy start/brake cleaner spray, but too much and you can hydrolock the engine ! If the engine starts and runs for a few sec then its fuel related...
    Sep 2009
    the saga continues....
    Afternoon again!
    So the saga continues... my mechanic has now told me that he suggests we scrap the car because a new fuel pump is so expensive - I thought a diesel audi at 141k was only just run in!! I've managed to get an error code from him...
    17978
    Does anyone have any thoughts as to what this might be?
    My mechanic has also told me that he won't put a rebuilt F&I pump on the car... needless to say I'm slightly annoyed and have decided to take the car elsewhere. I'm thinking about RSD in Daventry as they are only a couple of miles from my house.
    Jan 2004
    York
    1,654
    http://wiki.ross-tech.com/index.php/17978/P1570/005488
    Possible Symptoms
    • Engine starting but stalling immediately
    Possible Causes
    • Key(s) not matched
    • Instrument Cluster not matched
    • Engine Control Unit (ECU) not matched
    • Engine Control Unit (ECU) Power Supply faulty
    Possible Solutions
    • Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some)
    • Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module)
    • Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
    • Check Engine Control Unit (ECU) Power Supply (Relay)
    Special Notes
    • If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, in rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example)
    Would said mechantic want to be buying your motor off you cheap by any chance ?
    "Stick a V8 in it!"
    15,350
    As said, thats an immo fault, not a IP fault.
    Its odd that its just broken though, do you have a spare key you can try on the car?
