Results 1 to 26 of 26
Thread: rs4 maf on s4
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    rs4 maf on s4
    just out of curiosity what would be the outcome of fitting an rs4 maf meter onto an s4? they are 10mm larger diameter 83mm v's 73mm.. the flexi pipe leading to the y-pipe has a reducer gasket inside so would probably be a direct fit with a thinner one. would it allow more airflow or just reduce the pressure=reduction in air flow?
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    dont think it would give you more air flow as the air is coming from the induction pipes, you get more air from a less dense filter but doubt it would give you more flow=power
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,348
    Without a suitable remap it would make it run like crap.
    For a given airflow, the meter would read lower on the RS4 MAF because the housing is larger.
    TD5 Land Rover Defender build
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    awww..
    i'm fitting an rs4 exhaust system in the next couple of weeks with gutted precats and might lose the middle box too and fit a k+n filter, i was just thinking of other things to fiddle with while i'm there.
    i am getting my remap adjusted after the exhaust ....
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    are the rs4 maf's hitachi tho???
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    The RS4 MAF's are just as prone to failure as the Bosch ones.
    Mo power, mo problems
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    so they're all hitachi then rs4 maf's??? it wouldnt work anway then. it wasnt a reliability query just the typical male thinking of bigger is better...lol
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    you will need to get the car mapped with the new RS4 maf on, as your having it mapped anyway due to your exhaust going on you could do it at the same time.
    Jul 2006
    1,562
    Quote Originally Posted by s4marsh View Post
    Jun 2009
    173
    I have the RS4 maf on mine, had it as part of the upgrade to make the toy go quicker. Works brilliantly .
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    Quote Originally Posted by AudiMaz View Post
    wot power are you roughly ruinning then mate?
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    Quote Originally Posted by Dan Gliballs View Post
    panel filter not cone.. please dont cry
    are the rival filters better??? they're certainly cheaper
    itg, pipercross, what do you reccomend??
    Sep 2009
    Essex
    2,366
    a paper one tbh
    "Stick a V8 in it!"
    15,348
    Ye a paper filter is what you want.
    Turbocharged engine really isnt going to see any gains anyway. If the inlet is pressurised to 1bar then you have 1bars worth of air, whether the turbo has had to draw that in thru an open pipe, or thru a normal paper filter doesnt really matter to the engine.
    Sep 2009
    Essex
    2,366
    and cotton fitlers really dont seem to filter as well as paper (that is their function after all) and an oil filter has that chance of damaging the maf (the only car ive had with a maf and a special filter had a blitz stainless steel filter, so i cant comment on whether thats a myth or not)
    oil based filters cost money to maintain, far more money and hassle than it takes to just put a new paper filter in that will flow just as much
    if i get round to getting an s4, ill look into modding the airbox tbh
    Jul 2006
    1,562
    I recommend paper too.
    Have a quick read of this
    http://www.max-boost.co.uk/max-boost...mentairfilters
    "Stick a V8 in it!"
    15,348
    Matt: "Green Cotton" filters are oiled too mate. I pointed this out to a few folk on here a couple weeks back, with a link to the cleaning and re-oiling kit on the green website.
    The reason their oiled is because the filter material isnt fine enough, so they're relying on the oil to catch the dust. Might be fine on a series landrover (they had oil bath filters as standard ) but not on any modern engine.
    Sep 2009
    Essex
    2,366
    and before you can reoil it, you have to clean it with petrol to get the old gunk out
    and the oil costs 10 etc
    never again, paperfilters for me
    i think i can sacrifice the 0.000065bhp
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    MRC seem to do a paper air filter, why not check them out, ill see if i can get a link
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    check it out, its a group buy so maybe you can get it for cheaper
    http://audisrs.com/about7783.html&si...13cb6f34d065bd
    "Stick a V8 in it!"
    15,348
    40quid for a paper filter seems a bit ludicrous.
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    im trying top find out wot the difference in MRC filter is
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    http://audisrs.com/about6341.html
    check it out for info
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    Quote Originally Posted by Matt82 View Post
    says it all.. i'll save my money for petrol or new rear roll bar thanks lads.
    jcb
    Sep 2005
    uk
    4,077
    MRC one is foan isn't it? seems to be an ITG one
    wouldn't buy another ITG filter if they were 40p TBH.
    foam degrades and becomes part of your air charge!
    worse than no filter!
    Sep 2009
    Essex
    2,366
    ive ran plenty of foam filters before. ive not had one fall apart (yet)
