AH FabricationsVolks Autos
Results 1 to 18 of 18
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    Wiring loom swap..
    I will be swapping the wiring loom in my 1996 A4 (AEB engine) to the newer type (97>) loom to take a newer ECU.
    Will there be any compatibility issues with sensors etc.. AFAIK the lambda probe is slightly different and will throw a fault code but is there anything else to expect?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    Nope should be ok, you 'may' have a prob with the MAF, but thats not 100% ad the early (expensive) MAF covers the early models so should actually be ok
    Oct 2007
    UK - Midlands
    2,223
    That's ok then.. I have two older type mafs and a newer one in my Audi warehouse (garage) lol.
    I know the Lambdas are different as I ordered one for mine and it turned out the part changed for 97> cars... I have one spare now anyway!
    Got Audis/parts all over the place at the minute ha.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Yeah, I had a problem with my MAF when I spliced in an older loom... you need to keep your existing MAF and the connector for it... the other one 'might' not be compatible.
    But, if you're putting in a new ECU, then you should need to use a newer MAF too... I would have thought.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Oct 2007
    UK - Midlands
    2,223
    Yeah AFAIK the newer ECU, loom and newer MAF should just pretty much plug and play.
    Oct 2007
    UK - Midlands
    2,223
    ..wasn't there a difference between the CTS on the earlier and later cars?
    Apr 2004
    12,505
    Have you got the blue/green 4 pin one on yours?
    If so you are good to go. Some early ones had a seperate sender for the air con, grey IIRC
    Oct 2007
    UK - Midlands
    2,223
    Yeah it's the four pin one
    Apr 2004
    12,505
    I think you should find the MAF,the N80,the ICM, the coils,injectors etc the connectors are all the same for those too from memory. You need to move closer,lol
    Oct 2007
    UK - Midlands
    2,223
    Should be fine then.. cheers.
    The journey from yours to the Mids is lovely though. Maybe you should do it more often lol
    Dec 2006
    131
    exactly what i was looking to do... let us know how it goes :D
    Apr 2004
    12,505
    Quote Originally Posted by Lee Goodall View Post
    Once a few things are sorted, i might just do that.....
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by Byzan A4 View Post
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    TD5 Land Rover Defender build
    "Stick a V8 in it!"
    15,317
    You sorted out some fuel injectors yet for the T28?
    I've been looking at some cheap OE bosch injectors that will flow 475cc/min at 3 bar and should fit the AEB rail (they're a direct swap for Bosch "fatbody" EV1's in a different engine)... Think they'll do about 500-510cc/min at 4 bar, and you can get a full set, brand new, for about 80-100quid.
    You'll likely also need a new fuel pump, i doubt the standard one will be man enough to flow 475cc/min at 5-6 bar...
    Oct 2007
    UK - Midlands
    2,223
    Worth considering then.
    I was going for 415 or 440CC possibly Genesis or Delphi with the 4 bar FPR. A lot of the bigger Bosch injectors that I've seen have a narrow spray pattern.. which is obviously not good for multi-valve heads.
    "Stick a V8 in it!"
    15,317
    These are standard fit on a Vauxhall Astra VXR, and people use them as a direct replacement for the injectors on the C20LET engine, which uses the same Bosch EV1's as the AEB does.
    http://shop.ebay.co.uk/i.html?_nkw=V...1&_from=&_ipg=
    Few on there, a couple of them brand new, and one with a 99p start.
    Mate of mine has a set, so i can find out from him the bosch part number if you want to look up any more tech specs of them?
    Oct 2007
    UK - Midlands
    2,223
    Yeah that'd be brilliant cheers mate
