Monster MotorsportChris Nott
Results 1 to 28 of 28
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    HELP - why have I lost all boost?
    This morning on way to work my car lost all boost. Vacuum is as normal, the bailey dump valve open and closes as it should but I have no positive boost at all? It's a 1.8t btw. Any help much appreciated
    Drizz Developments - Audi A4 Avant Quattro Sport
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    A hose could have popped off. Vacuum would be unaffected by that.
    Mo power, mo problems
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    Ye it does sound a bit like a hose, or some other boost leak like a split intercooler. If it was ECU or boost control related you'd end up on wastegate actuator pressure which is around 4psi.
    TD5 Land Rover Defender build
    Feb 2007
    Liverpool
    1,693
    If it was only a split intercooler (or any other kind of minor leak) you would still expect it to reach some boost, that's why i'm thinking of somethign like a major boost leak, ie: hose completely popped off.
    This happened to my S once midway through a spirited drive up in Scotland. It was pretty obvious because as soon as you tried to accelerate hard it was like stomping on the brakes. You could also hear the air rushing out.
    my96A4Turbo's Avatar
    Aug 2009
    edinburgh
    happend to me last week,,,,the pipe that runs from the actuator to the inlet had just came right off ( the pipe was hard and brittle& just crumbled away)........
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,071
    The actuator rod could have come off the wastegate arm. This means the penny remains in the open position and no positive boost is achieved
    Life begins at 140mph
    www.passionford.com
    "Stick a V8 in it!"
    15,287
    or the penny valve could be embedded in the cat somewhere :P
    penny valve "fell off" on mine according to the service history, somewhere around 120k miles.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Hmmmm Well ive taken the undertray off and check the hoses and all seems intact. Intercooler looks fine too. No whistling to indicate a boost leak so can only imagine its the turbo area. Ill go and check that inlet to actuator pipe and i doubt i can get to the actuator arm but ill try and check that too.
    Not a happy bunny today
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Could just have gone into limp mode if the turbo's spiked. Have you driven it since you stopped the engine?
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Feb 2007
    Liverpool
    1,693
    Limp mode and/or actuator failure would still result in wastegate pressure (ie: a bit of boost would still be produced because the turbine is forced to spin until the pressure of the exhaust gases open the wastegate (it remains closed by a spring until this point).
    I suppose it could be something causing the wastegate to remain open, ie: broken wastegate spring.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    A broken or incorrect MAF can cause similar problems too. I installed the incorrect MAF in mine a while back and it wouldn't run, tried to stall when accelerating, etc...
    PM me for more info
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Right to answer some Q's. Yes ive driven it about 50miles since over 3 journeys. It drives and idles normally, just wont boost. No management light, no noises, just no boost.
    Im thinking as theres no audible difference it wont be boost leak, and no management light means it wont be electric. It must be turbo/actuator....
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Yeah... a MAF failure would produce a warning light.
    PM me for more info
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    Drizz you VAGcom'd her yet?
    Maf as a complete fail can produe a MIL,assuming it has one, I can't remember what year your car is AEB ones don't have an engine light
    But MAF lowsignal may not put a light on, as it could be borderline
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    I dont have VAG com unfortunately.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Will disconnecting the battery remove any fault codes like it does on Vauxhalls? Thinking if i disconnect it, leave it then reconnect and see if it drives ok intially?
    Oct 2007
    2,597
    I'd be inclined to concentrate on the turbo area...
    Have you removed the intake pipe from the turbo? I'd do so, and check the actual turbine shaft isn't broken. I have a 2000 A6 1,8T, the shaft had snapped in two, so the exhaust turbine was still spinning, but seperate from the compressor turbine.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Quote Originally Posted by Siena View Post
    So take off the airbox to turbo pipe then start it up and see if its turning yeah? Or if its snapped itll fall out anyway?
    Oct 2007
    2,597
    No, just remove the turbo intake pipe, and check the compressor shaft by hand. You'll soon know if it's still connected to the turbine shaft.
    "Stick a V8 in it!"
    15,287
    The only thing the ECU can do is open the N75 and let the actuator see all the boost. The actuator opens the wastegate at 4psi, so if it was an electronic issue it would give you 4psi...
    MAF etc could cause it, but it'd also show other signs of running crap.
    I suspect its a mechanical issue with the turbo itself. Can you hear any "spool" noises at all?
    I'd either try and get a vagcom scan, or remove the cat/downpipe and check the wastegate.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    No un-normal noises at all. Ill be removing intake pipe tuesday and seeing if the shaft is obviously knackered and go from there....
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Well the turbo shaft feels normal. Has to be something electric im now thinking as surely the boost guage is -20 off throttle and 0 on throttle. If the turbo wasnt working at all surely it would stay in vacuum? or am i talking nonsense?
    "Stick a V8 in it!"
    15,287
    When our penny valve broke (before we got the car) the initial diag report says 2psi peak boost...
    As i've said, if its electronic the turbo would still run actuator pressure, which is 4psi. The ECU cant force the boost any lower than that.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Must be penny valve then
    "Stick a V8 in it!"
    15,287
    When the penny valve breaks (or the actuator/wastegate jams open) the turbo will still spool, as some of the gas will still flow thru the turbine...
    Hence you will still get a tiny amount of boost.
    "Stick a V8 in it!"
    15,287
    Shouldnt be too hard to check, pop the cat flange bolts and wiggle it back a bit then look in the crack?
  28. #27
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    ill get it done soon, gonna vag com it first just incase
  29. #28
    Apr 2004
    12,500
    Have you solved it yet Drizz?
    It's exactly the symptoms we now have with the A3
