Sky InsuranceEM Tuning
Results 1 to 7 of 7
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    s4 dooe blades on a4?
    do they fit on the same as the a4 ones? im in the process of getting s4 skirts/door mouldings and the sill plates from a pre facelift s4 to go on my facelift a4,just want to check its going to go on ok.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    What is a dooe blade?
    Mo power, mo problems
    May 2008
    perth
    1,197
    ha ha,meant to be door blade.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    they should do, each S4 door blade comes in 2 parts. your existing door blades have a rectagularish plastic fittings which the back part of the door blades slide onto.
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    jcb
    Sep 2005
    uk
    4,070
    yep have them on mine, may need to get some new fixings to fit properly
    Feb 2007
    Liverpool
    1,691
    I'm still none the wiser, what's a door blade? (honestly)
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    the rubber strip on the bottom of the doors
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
