do they fit on the same as the a4 ones? im in the process of getting s4 skirts/door mouldings and the sill plates from a pre facelift s4 to go on my facelift a4,just want to check its going to go on ok.
they should do, each S4 door blade comes in 2 parts. your existing door blades have a rectagularish plastic fittings which the back part of the door blades slide onto.
