Chris NottMonster Motorsport
Results 1 to 11 of 11
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    pre facelift s4 bumper on facelift a4?
    will i need to get pre facelift mounts or will the ones i have work?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    i THINK S4 bumper mounts are different to normal cars anyway, so you'll probably need the S4 bumper mounts.
    Check the part numbers on vagcat?
    TD5 Land Rover Defender build
    Feb 2009
    30
    I reckon you will need the S4 bumper mounts mate I did when fitting my s4 front bumper to my face lift 1.8T
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    When i fitted mine i had to buy the correct mounts. I believe there are places on Ebay that sell a "kit" to allow fitment. The bumper shocks will work, but the side mounts 99% won't
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Yes you defo need the side brackets which allow the bumper to clip on to
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    ^^^ what they all say yes 100% different i have a pic somewhere the S4 side brackets are a lot smaller than the standard A4 you will just need to move a few clips behind the brackets to a different postion the square holes are already there
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    jcb
    Sep 2005
    uk
    4,077
    i have a prefacelift s4 bumper fitted to my facelift A4 using the a4 bumper mounts and bar.
    you need corresponding pre or post facelift s4 side mounts for sure.
    its cheaper and easier to remove the s4 bumper bar and fabrcate your bumper bar to the new shell.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Here it is mine was a facelift bumper though dunno if the side mounts are different
    A4 Left; S4 Right
    "Stick a V8 in it!"
    15,385
    That looks quite like a pre-facelift side mount?
    Feb 2009
    30
    Hey Guys, mines a face lift model and I've attached some pics for your interest. I had the S4 side mounts supplied with the bumper and had to buy new S4 bumper arms/mounts to attach to the front..
    New S4 front mounting arms
    And the finished article with satin black grill and badge.. Also had the Seat splitter fitted underneath..
    "Stick a V8 in it!"
    15,385
    The Side brackets are the same as normal pre-facelift A4 bumpers.
    The bumper shocks are specific to the S4, and are the same on both pre and post-facelift S4's
    This is because all S4's are fitted with the same "pre-facelift" bumper.
    Timmy: that looks stunning, you need to "joey mod" the headlights though!
