Chris NottSky Insurance
Results 1 to 10 of 10
    marsie's Avatar
    Aug 2009
    sheffield'ish
    61
    Parrot ck3100 into b5 S4??
    I have recently bought a second hand parrot ck3100 to put in my S4 but have a few queeries. if i connect the power leads to the fuse box(blue/red/black) and 2 inline connectors to the radio but nothing else it all works but when an incoming call comes in, the phone ringtone comes through the speakers at full volume and turning the volume knob makes no difference at all also the radio/display dosent show anything
    If i leave either inline connector out and connect the yellow mute wire instead,the radio mutes(and comes up telephone on display) but the phone still rings instead of the parrot
    Any idea what i am doing wrong??
    By the way i have a 1999 S4 with concert system and bose and the parrot has a 06-015 adaptor thingy
    Paul
    1999 Audi S4 2.7 bi-turbo*SOLD*
    1997 landrover defender 100" winch challenge truck
    1998 Range rover 4.6 autobiography
    Adam-D's Avatar
    Dec 2007
    wirral, merseyside
    458
    you have 2 options. - remove the bose system,
    or change the headunit. to say a std cd player with the right leads, or a bluetooth cd player with the right leads,
    the parrot is running its own amp, then the cars own amp it double-ing it.
    stuff for sale.
    black door cards 50
    black textured "carbon" trim 30
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Yeah, exactly what Adam said.
    Rach's TT has Bose and it was a pig to fit a Parrot system. I ended up buying a secondary Parrot speaker to run it all through. Trouble is, it doesn't mute the radio when a call comes through. Very frustrating.
    I have the exact same Parrot system in my B5, but with an aftermarket headunit and it works perfectly!
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    all the headunits have a mute at the back , it says TEL in the longer plug i thing . Just connect the parrot mute to this and it will mute the radio and display telephone
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Hmmm... I did try that, but with no effect.
    Rach's TT actually has an aftermarket headunit, but still utilises the BOSE system... and whatever way I tried it, it wouldn't work. That's why it's now got an external speaker installed.
    Grrrrrr! lol
    PM me for more info
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,930
    Presumably its because the head unit doesnt output amplified signals to the speakers, it just feeds a line level output to the bose amp?
    I've not dealt with that particuar system, but when i did audio fitting for halfords a few years back the system they sold spliced into the speaker outs of the head unit, so you'd need to install it between the bose amp and the speakers, rather than the headunit and speakers, otherwise it would end up getting amplifed twice and blowing your ears off :P
    TD5 Land Rover Defender build
    "Stick a V8 in it!"
    14,930
    http://www.parrot.com/documents/en/s...taudi_line.pdf
    Seems that the unit has both amplified and line level outs. You just need to find the correct line level wires and patch them into the right places. Either the head unit itself will have a "line in" or the bose amp will have a "line in" for the telephone.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    thats right to do it properly you need to get to the hi-level going to the front speakers and splice into them , you will still need the tel mute conected to the headunit to mute the radio , dont forget you will require a switched feed also to make it work properly
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    My one works when a call comes in it mutes the front speakers and directs the call through these leaving the radio for the peeps in the back. All functions work via the remote and raido still controls the rear speakers. Its the 9100 i have i think.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    thats right you have the hi level (normal) speaker outputs in the iso harness for fronts only , The muting is been done in the parrot its self rather than the headunit . If you want the head unit to mute completely you need to conect the yellow lead coming from the parrot mute (long black box)
