Results 1 to 7 of 7
    Oct 2006
    88
    vag com - ignition short to ground
    Hi got an intermittent misfire, just pulled this code
    17771 - Cylinder 3 Ignition Circuit: Short Circuit to Ground
    P1363 - 35-10 - - - Intermittent
    any ideas?, could it be the plug? or the coil ?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,347
    sounds more like the ignition driver itself
    Sits atop the airbox.
    The ECU cant "see" the coils, so for it to notice a problem it must be the driver i recon.
    TD5 Land Rover Defender build
    Oct 2006
    88
    thanks for the pointer
    i 'll check out the cost
    anything i can do to be sure?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    there are two modules there, one for each bank, swap them over and see if the fault moves. That should help eliminate the ICM
    "Stick a V8 in it!"
    15,347
    It a 6 cyl then?
    Apr 2004
    12,520
    They have an S4 don't they?
    Oct 2006
    88
    yeah s4
