Chris NottMonster Motorsport
Results 1 to 10 of 10
    Mar 2007
    salford gtr manchester
    556
    v6 30 valve thermostat replacement
    hi all i cant put it off any longer as there seems to be a bit of a nip in the air and i need to replace the thermostat on my t reg 2.8 30 valve quattro i know its behind the timing belt (stupid design) but i was wondering if it is possible to replace it without removing the belt . i dont realy want to replace the belt because the last owner had it done less than 30000 miles ago do you know of any garages that would take on this job in the greater manchester area or have any of you actually done this and can pass on a few tips any information would be very much appreciated
    Jan 2004
    York
    1,641
    Yes you should be able to get the thermostat housing of with out removing the belt. All you need to do is slaken the tensioner when you come to remove the house.
    8V S3 Sportback with options on order
    Jan 2007
    65
    I did this myself after the garage I gave it to spent 45mins trying to find the damn thermostat!!
    You don't have to remove the timing belt, just edge it forward so it is half off the cogs. Elsawin says that you just need to have the front end in 'service mode', but I found that too difficult as there is very little room to manouvre. I thought I had finaly done it and put it all together, then the last job is to top up the fluids when I found a drip drip drip noise
    This time I undid a few more hoses on the front and opened the panels out so I could get a good pull on the belt to get more room. This made it alot easier to remove the cover and place the 'O' ring correctly.
    Nothing technical, just lots of nuts, bolts and hoses to deal with. Personally I would suggest you take a weekend and do it yourself or take it to a VAG specialist who won't charge you for standing there scratching his head trying to figure out how to do it.
    You will notice a big difference in how quick the engine warms up after and it should also improve your fuel consumption.
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    Quote Originally Posted by Nige P View Post
    Ahhhh. The stories I could (and have) told.....
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    Mar 2007
    556
    ok so this week i am getting the parts together to do the thermostat on saturday .whilst the front is off i am going to replace the front snub mount as i have got a clunk in the drive train when changing gear have any of you done this would you recomend an uprated snub mount or would you stick with a new genuine item also any ideas where to buy the uprated ones from any info would be welcome
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    uprate it the cost next to nothing , you can have a look at my car in bits if you like to give you an idea of how the front comes off etc
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Mar 2007
    556
    Quote Originally Posted by andybnwc View Post
    thanks for the offer where are you
    Mar 2007
    556
    hi all i finally replaced the thermostat yesterday it went a lot smoother than i was expecting i took the complete front end off all the time is in the dismantling replacing the stat took 10 minuite i started the job at 11.30 and was done for 3.55 pritty pleased considering it was the first time i have removed the front bumper and lock carrier shes now up to temp in about 2 miles happy days
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    well done sorry i didnt reply in time
    Mar 2007
    556
    forgot to mension i also fitted the APR snub mount not done many miles yet but initial feeling is the car feels much tighter not noticing any vibration yet all in all pritty happy with it
