Badger5AH Fabrications
Results 1 to 21 of 21
    May 2009
    23
    Arrow For those that have done the OEM RS4 wb conversion
    Any regrets?
    I wish I could just pick up a genuine RS4, but we weren't as lucky here in the states. Converting my sedan is the next best thing. I can get the parts I need for a pretty good price, however, labor costs are going to kill me! Throwing all that money into a car worth so little nowadays seems crazy. I'm trying to convince myself that it'll all be worth it in the long run if I end keep my car for a few years lol
    Rich | Kiss French, Wear Italian, Drive German
    Flickr | 2001.5 EPL stg III Pearl White S4
    EPL | ER | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | BBS
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    Looking at doing the conversion myself in the future, the only pain is the rear arches and making a rear bumper to fit, all the rest are pretty much bolt on parts, wasgonna do the front bumper, front wings doors and trims all myself, the have a bodyshop cut in the rear arches and paint, should save some labour time and be fairly easy, just a pity its hard to find the parts for reasonable money!
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    Oct 2007
    2,597
    No regrets.
    Stapo, you can go widebody without replacing the rear quarters.
    And without so much as a sniff of fibreglass.
    stapo69's Avatar
    Mar 2007
    966
    Tell me the way oh wise one! You have me intrigued....
    Oct 2007
    2,597
    It involves cutting triangular sections out of the rear arches, expanding them, then welding new metal into the resulting larger triangles.
    I saw the same done on a Swiss B5, someone on here has also done the same.
    stapo69's Avatar
    Mar 2007
    966
    That makes sense, not a bad idea, best find myself a good bodyshop!
    May 2009
    23
    Quote Originally Posted by Siena View Post
    Have any pics of any B5 that went about doing the rear this way? Was it OEM Looking?
    May 2009
    23
    Quote Originally Posted by stapo69 View Post
    Yea, if I were to do this, I would install the front end and sides myself. Have the body shop deal with the rear arches, doors, and rear bumper.
    Oct 2007
    2,597
    Quote Originally Posted by bimmerchop View Post
    I'll see if I can dig out the one on here.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Aidan from Bahnstorm in Nottingham did this with his S4, although IIRC he only did this on the passenger side as it was too difficult to do the panel with the fuel cap. Looked mint.
    Mo power, mo problems
    jcb
    Sep 2005
    uk
    4,077
    no there is a link on here somewhere showing it.
    was looking for it myself. the full build in shown, he just had to buy rs4 rear doors.
    May 2009
    23
    That link would be real helpful. I'm trying to search for it, but not having much luck
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    He only did one side like that the other was done with a RS4 rear quarter.
    I did this conversion and most of the work bar the rear quarter where done by my self.
    The rest of the stuff is all bolt on and you can save your self loads if you strip the car down your self and put it back together your self.
    The biggest part is the rear which if you have a look through my photobucket album will give you some idea what you have to do.
    http://s6.photobucket.com/albums/y22...udi%20Project/
    May 2009
    23
    Okay, I'm a bit confused regarding something...
    I thought that when replacing the rear doors, it would be pretty much a straight swap, meaning that it's a complete door assembly that bolts right on. I would just need to swap in the needed electronics and door card from my current S4. However, someone mentioned to me that they are door skins that you have to tack weld into place.
    Now, I know they sell the complete door just without the internals and door card that can easily be replaced, but do they also sell just the door skins that need to be welded onto the door frame?
    Quote Originally Posted by docurley View Post
    Thanks for the link. Did you run into any surprises when swaping out the parts you did yourself?
    jcb
    Sep 2005
    uk
    4,077
    you need more than a door skin. you should be able to buy complete doors.
    The mounting points and latch is in teh same place, only difference is where the trailing edge lines up with the outer skin of the rear wing
    jcb
    Sep 2005
    uk
    4,077
    did you have a supercharged RS4 to strip when you did this? what is the car in the pic list?
    stapo69's Avatar
    Mar 2007
    966
    IIRC the supercharged engine was a 2.8, what Docs car originally was before a 1.8t conversion, quite a rare supercharger kit too.
    jcb
    Sep 2005
    uk
    4,077
    lovely noise, charged v6
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Not quite right that was my first A4 a 97 2.8 30v which I bought a new PES Supercharger kit for and was a great car but a 1.8T offers more and when a 1.8TQ came up for the right price just before I was ready to do the conversion and bought it and the rest is history.
    Ok back to the swap.
    The back door need the whole window frame which contains the whole contents of the doors on one frame held in place by 4 bolts and shims as the RS4 Avant as diffrent window frames to a saloon/Sedan.
    The front doors from your S4 can be used but you will need to de-trim the outside and grind of the pins and make good.
    Front wings will just bolt on but you will need new wheel liners as the S4 ones will no longer fit the larger arches the front bumper will need the bumper shocks as they are longer but you could get round this by using washers.
    The rear quarter will also need the inner wing not unless you body shop can either fab something up or even fiberglass the void fron the S4 inner wing to the RS4 outer wing/fenders.
    The rear bumper (if using your current bumper) will need to be heated on the side and teased out to follow the RS4 wing/fender shape but I would buy a Euro S4 rear bumper and do the same to that using a heat gun and your knee making sure you don't over heat it.
    Bonnt/hood are the same and so are the lights so nothing need hear but the front wing indicators are different shape to standard so you will need to replace them, I think they are TT units/B6 A4 units.
    Engine sump gard is different and the S4 unit will no longer fit so either leave it off like I did or a RS4 unit will cost 200/$360 to get the correct one.
    Petrol flap will also be needed to flow with the RS4 rear arch profile,
    Side sills/Skirts are stuck on with double sided tape as is on the originl and one or two screws either end in the inner wing/fender. You will also need to bond it to the under side as the mounting point under the car are different and you wont be able to secure it in the same way as the RS4 plus you will have no reason to remove it.
    This should cover most of the conversion and the pictures will do the rest.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Just realised you’re from the Zine.
    May 2009
    23
    Yup, on AZ. Thanks for the info.
