Chris NottEM Tuning
Results 1 to 12 of 12
    andysAko4's Avatar
    Oct 2007
    Ponty-carlo
    33
    THS Exhaust Manifold -ever fitted one ?
    Jst got my new manifold and tired fitting it yesterday.Ok up to putting nuts back on along the top and no room the put the nuts on !!.After alittle got some on but unable to tighten up. Any ideas any one pls
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    I removed the studs from the head and used socket head cap screws(m8 x 40 iirc ) and installed most of them into the mani before attempting to fit it. I then used a long ball ended 6mm allen key with additional lever handle to get them tight
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,912
    The only problem with that is that your torqueing the bolts up against an alloy head...
    Your at more of a risk of ripping the threads out the head than using studs.
    I suspect you'll need to modify some spanners or something to get into them.
    TD5 Land Rover Defender build
    Apr 2004
    12,357
    Will not get a spanner in there, i tried all sorts 1/4 dr sockets are too big even. Using the allen bolts is a common mod but as stated care must be taken. It why the length is important, any longer bottoms out, and any shorter may strip the threads
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    surely that is very bad design if you cant bolt it on properly?
    Apr 2004
    12,357
    Seems to be par for the course in the cast K03/4 manis
    andysAko4's Avatar
    Oct 2007
    Ponty-carlo
    33
    Thks Mark,a fountain of knowlwedge,what would we do without you ....Did you use the washers with the bolts when fitting? I was expecting to have to make a tool or socket.
    I have pm THS about this. Ill post their reply when I get it.
    Should be interesting.
    Apr 2004
    12,357
    I used the Thick washers i think as the first lot of bolts i had were slightly longer so i used the thick washers, i have got pics somewhere......
    Apr 2004
    12,357
    Best i could find
    jcb
    Sep 2005
    uk
    4,070
    goose neck open ended spanner
    Apr 2004
    12,357
    it works on the top nuts, not on those damned lower ones..... GGGRRRR
    andysAko4's Avatar
    Oct 2007
    Ponty-carlo
    33
    This is reply I got from THS , Not sure about filing though LOLl
    It should be possible to fit without removal of the head. You may find it easier to use a spanner rather than a socket on some of the nuts. Are you sure that the manifold is located true on the head. We had one customer mention that the top of the manifold flange just came into contact with the top of the head casting and he had to file a small piece of the top of the manifold.
    Hope this helps
