Monster MotorsportVolks Autos
Results 1 to 8 of 8
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,914
    Rear Diff Oil and Seals
    So craigs car just passed its MOT, no issues, apart from the tester said that rear driveshaft seals were leaking.
    First things first we wanna make sure theres enough oil in the diff, since we dont know how long they have been leaking, what kinda oil should we be topping it up with? Any gen on whether the diff needs a special drain/fill key, or is it something off the shelf (yes i know i could just look under, but i dont have the car :P)?
    secondly, we need to change the rear shaft seals, now, is this a big job? Whats involved in this one? Any specialist tools required for it?
    TD5 Land Rover Defender build
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    If there's just general sepage then you might be ok. Mine have been weeping since I bought the ole girl. I just keep mine topped, (which reminds me!) Now, I'm ashamed to say I've never done the job myself but the diff fluid aint that pricey and I believe is an allen bolt on the drivers side. Undo allen bolt fill to hole level. I may be wrong, definately double check this. As for the job of the diff seals, when I got a specialist (about the only I've ever had any faith in) look at replacing the seals they advised that getting into them may reveal further probelms that wouldn't need address if the diff was left intact, again, this may only be due the high mileage on mine but something else to think about.
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    LPG Abuser & have VAGCOM
    Aug 2005
    Essex
    167
    Have a closer look as the "oil" may be leaking from where the CV joint bolts on to the stub axle that comes from the diff unit, I have one sitting in my garage and it would appear that the join do ooze some muck. Get yourself a Workshop manual (Elsawin) from ebay - there is a diff unit strip down, so you can see if you're brave enough!
    Michael
    Jun 2007
    High 'C's
    1,130
    http://www.audiworld.com/tech/misc.html
    Just found this... may be of some help.
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    jcb
    Sep 2005
    uk
    4,070
    soupie did his by himself IIRC
    its a large allan bolt to get on 14mm springs to mind.
    I have always used redline diff/box oil
    "Stick a V8 in it!"
    14,914
    Seems its just 75w90 GL5 that it needs.
    That thread shows the drain plugs are just hex keys, but doesnt mention the seals themselves,
    I'll have a search later and see if i can find anything.
    Jul 2007
    London
    3,082
    That thread shows the drain plugs are just hex keys, but doesnt mention the seals themselves...
    There are no seals on the plugs just clean well and refit making shure no grit makes-it inside ! I would use the dealers stuff as i know at least 3 quattros being dammaged by using alternative "suitable" oils. I had replaced oils inside gearboxes and diffs off high mileage cars and the oil was a bit low but still within spec, no swarf or foreign particles and still a honey colour.
    "Stick a V8 in it!"
    14,914
    I meant the seals on the driveshafts, as thats where its leaking from.
