    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Replacement key querie?
    Wheres best to try for this type of key? Or can you use newer type of keys for the B5? Also, i assume it needs coding, who does this appart from Audi?
    Key still works but alarm buttons need to be pressed hard to get them to work now. Cheers.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    whats your central locking pump part number?
    and what year is your car?
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Quote Originally Posted by olds_kool View Post
    Car is a 97 on a P. Will have to get back to you on the central locking pump no. need to have a look. Do you do replacements?
    Project RS28 build
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    just trying to work out if you can use a flip key as a replacement as ive never seen that type for sale new/uncut
    if your pump p/n starts 8L0 then flip key remote part should work but immo transponder (chip) was changed around 97 if you have a seperate immo box then youd probably need a new chip for the key part as these are use once only, if you have the immo built into cluster you should be able to reuse chip in a used key
    kev
    90 eunos roadster
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Thanks for info mate, will get a look at the number, hopefully shed some light!
    Project RS28 build
