Monster MotorsportEM Tuning
    imported_Cali
    Creaking front end
    Can someone out there please help. I have an 2000 A4 turbo Quatrro that has only just started creaking on the slightest of suspension travel - it is driving me crazy can some one please help. Do I need to replace the multi-link bushes - if so which ones. This hot dry weather isnt helping.
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    Re: Creaking front end
    bounce the left and right side of the car which ever side makes the noise you need to replace the lower straight ball joint for that side, there is a different way to tell each of the noises apart!
    Nov 2003
    Wa, USA
    248
    its your control arms. What you need to do is take a look at your balljoint and see if there are any crakes or tears in the rubber sections around the ball joints. And replace them accordingly. The other way to find out which bushing is causing the squeeking is to buy some WD40 or something similar and spray it on one of the bushings and then drive the car and if it continues, then spray it on another. That way you will find out which one has gone bad
