Results 1 to 10 of 10
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    help in manchester area
    Im part way through doing a engine pull in my stolen recovered S4 before i go and rent a crane has anyone near manchester got one i could borrow and maybe even help with the heavy bits ?
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Hi andy i thought your S4 was when someone fell on it or have i mixed you up with someone else, whats wrong with your engine?
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    We had a break in and they stole the S4 and crashed it . the engine has broken of its mounts and moved back .I need to pull it complete with subframe to see whats actually broken.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Ok any tips on the propshaft bolts got 2 out but now need to turn it , i presume jacking 1 rear wheel will be enough to do this? would it help if i drop the subframe a little to get more space to work on them?
    Oct 2007
    2,597
    Andy, are you referring to the front half of the subframe, or rear?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    yer if you jack a wheel and pop the tranny into neutral you should be able to turn the prop.
    Not sure about lowering the subframe, i'm not too familiar with the underside of a quattro.
    TD5 Land Rover Defender build
    Oct 2007
    2,597
    You don't need to lower the subframe, Andy.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    ok no worries ill just give it a spin , one other thing where is the best to use axle stand when dropping the subframe?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    If you remove the alloy shield from below the rear flange of the gearbox, its only 2 trorx screws, the prop ones are then accessable with it in place.
    You will probably find the gearbox mounts sheared too, the pull i just did had intact engine mounts, but smashed gearbox ones, also the impact had pushed the timing belt cover into the belt shreading it and causing the belt to jump damaging velves
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    engine runs fine fortunatly but wont drive when in gear , i can get to the prop bolts just not much room to use a socket , i think it will help if i remove the twin pipes , think thats gonna be my next step
