    Aug 2009
    1998 1.8 T intermittent engine fault
    I have a intermittent fault with my engine,
    It will suddenly lose power and i have to rev it quite high to be able to keep moving
    when it starts to do the problem it will idle erratically nearly cutting out but then revving up to 2500rpm and back down to 300 ish.
    if i stop the engine and restart it will be fine for a while, it could be 300 miles or 3 miles before it does it again.
    the engine also seems to run very unevenly sending vibration into the car and some black smoke and liquid comes from the exhaust (only when doing the problem though) but the rest of the time runs smoothly and clean.
    I have had the car plugged in at a main dealer and there are no faults logged.
    It seems to do it more when the fuel tank is below 1/2.
    I have been told it might be the MAF sensor??
    Fraser's Avatar
    Aug 2003
    the north
    586
    yep sounds like MAF
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    I might even suggest the coolant sensor.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    it could be quite a few things.
    Ignition amplifier dropping sparks for instance, or as has been said MAF or CTS.
    I would get a vagcom scan done and see if it shows anything up.
    TD5 Land Rover Defender build
    Aug 2009
    As I said in my post I have had it plugged in at a main dealer and no faults came up....
    So it looks like i need a MAF... anyone got any advice where i can get one? some guy on ebay is selling them for about 30 seems a bit dodgy...
    Fraser's Avatar
    Aug 2003
    the north
    586
    the dealer or eurocarparts
    get a proper bosch - anything else is not worth it and will cause problems
