Volks AutosMonster Motorsport
Results 1 to 10 of 10
Thread: max offset?
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    Question max offset?
    Hi, im looking at some A3 8P (2003) alloys as an alternative to the current 16's i have. I know they're still 16x7" so thats not an issue. The offset is 50, will these fit? car is standard height (SE model) and will be running the normal 205/55 rubber.
    1999 1.8 SE A4 100% standard tank, all green.
    Alpine old skool
    Helix RS6 - PHD PRO 4070
    Coral 10" passive setup - PHD 2200
    Jul 2007
    London
    3,211
    ET 50 is too high and they gonna foul te front and rear suspenssion. You will need spacers or buy the right offset...Stick to ET 35 or ET45 and they will fit without trouble given that the tyres are the right size..
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    Or if the wheels are cheap enough , you could get some spacers to set the offset closer what you want. Your OE wheels will be et 42, so a 10mm spacer will be somewhere in the middle
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,316
    OE rims are ET45, but a 10mm hubcentric spacer should be fine.
    A lot of people run ET38 or ET35 and usually on 8" rims rather than 7's so ET40 (ET50 + 10mm spacer) will be fine.
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    are they 5x112?
    Oct 2007
    2,597
    Quote Originally Posted by jcb View Post
    are they 5x112?
    If off an 8P A3, then yes, they'll be 5/112.
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I run ET45 with 10mm hubcentric spacers on the rears... hope that helps.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Jul 2009
    88
    I'm hoping my TT/S4 wheels (ET43) will fit along with 10mm spacers.
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    in that case, any suggestions for where to get longer bolts to compensate for the 10mm spacers, and will the rims/tyres still be legal, in terms of being within the arches?
    Alpine old skool
    Jul 2009
    88
    Quote Originally Posted by easytease View Post
    Most places will provide the longer wheel bolts you need when you buy the spacers. I know DPM performance do as I've just purchased some from there.
    As far as I'm aware, as long as the tyres don't protrude from the arch in any way then you'll be fine. You're only talking 10mm anyway so I'm sure you'll be fine.
    Dave
