Volks AutosEM Tuning
    Jul 2009
    6
    parts! dont no what they are called!!!!
    i dont no if any one can help but i think i have found a problenm with my 2.8 quattro 96!
    there is a pump that has some pipes coming off of it. located under the abs pump does any one no what this is called!
    this pump also has a pipe that connects to a diaphram type thing that is on top of the engine and has an arm that connects to the throttle linkage on some ball linkages! would also like to no what this is called?
    as think this could be the problem with the idleing!
    thanks james
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Thats the cruise control pump under the ABS, and vacuum motor connected to the TB. Wouldn't expect it to have a bearing on idle tbh
    Jul 2009
    6
    well i pulled the pipe off of the tb! and there was no vacume at all and then we pulled the diaphram up and she began to idle! so i was sorta thinking this might be my problem!
