EM TuningVolks Autos
Results 1 to 39 of 39
Thread: B5 Boost Levels
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    B5 Boost Levels
    Just as a test i decided to see what boost my TQS was pushing.
    From 3k in second gear i got 9-10psi, in third gear 12-13psi and fourth 14psi
    I want more boost lower down lol
    Anyone else checked their boost in this way? Im interested in standard and remapped cars.....
    Drizz Developments - Audi A4 Avant Quattro Sport
    Jun 2009
    101
    You don't fully load up the engine in the lower gears so you may not get full boost.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    I think its more related to how the map/ecu controls the N75 valve to ramp the boost up. If you sealed off the actuator feed you'd probably spike 20+ psi in second.
    What you'd really want is the N75 to hold the wastegate shut until you reach max boost, then start controlling it, but it tapers the boost in slowly instead.
    I dont know if this is because the engine has no boost sensing, or if its just supposed to make the car more civilised to drive.
    You might find that an N75J will help bring the boost in harder, or perhaps converting to some other method of boost control, but if you bring it in too hard, you may well find you'll get fuel cut.
    A different remap might help too.
    TD5 Land Rover Defender build
    Jun 2009
    101
    Closing the wastegate in first gear would make no difference.
    "Stick a V8 in it!"
    14,907
    I would say it would.
    In first your thru it that quickly the ECU will barely ramp the boost at all. Whereas no wastegate would see the turbo producing the maximum possible boost in the time available.
    Go pull your boost sense line and see what happens...
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I've put a N75J valve on mine, plus a TT-225 DV, and I don't think it's made any difference to mine at all.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    Drizz so you are chipped then? Boost levels depend on load . So the higher the gear, the higher the load.
    Drizz I can go out and check mine for you if you like 1,2,3,4 yeah? I am chipped
    Giles, i expect your ECU is compansating for the J valve and cancelling it out, as you get that soft limp with any N75 don't you?
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    No mines standard...
    Yeah have a go see what you get...
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    When you say 'soft limp', I assume you're referring to the loss of turbo boost in the car!
    Yeah, it happens with all N75 valves. Rubbish!
    PM me for more info
    "Stick a V8 in it!"
    14,907
    J valves can cause boost cut, as they allow the MAF values (ie the boost) to climb too quickly afaik.
    Apr 2004
    12,357
    Drizz, they are awfully high values for a std car even under load.
    I make
    1st 18
    2nd 22
    3rd 23
    4th 22 but not really enough of road for proper test, but these are the max spikes gradually lowering when nearing red line
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    Quote Originally Posted by Drizz View Post
    I would say the boost figures you have stated are very reasonable for a unmapped car. If I remember correctly standard boost would be around 0.8 Bar, which equates to about 12 PSI. Anyway its not about how much boost is generated its more important that it holds that pressure, hence the N75J valve.
    Facelift S3, Sprint Blue, Bucket seats, Sunroof, Sat Nav, Bose, Elect Mirrors, Light and Rain, Interior Light pack, Flat Tyre Warning, GSM Phone Prep, Led upgrade, Illuminated speaker grills.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    The figures i stated are what it holds. It doesnt spike as such, it peaks and holds...
    "Stick a V8 in it!"
    14,907
    Mark: its a TQS mind, so it will run a little more than a stock AEB.
    I think its just mapped like that, gentle introduction of the boost to make it nice and refined to drive.
    The standard turbo will be able to hold 12psi thru most of the revs, once chipped up to 20psi though, it will drop off as the revs climb as the turbo cant flow enough air.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    so not worth a remap till i get a t28 then....
    Apr 2004
    12,357
    I thought it was 8 max for AEB and 11 max for TQS?
    My AEB map pulled around 12 PSI most of the time tbh. Maybe he is just lucky.
    Drizz as for re map, it depends how quickly you end up going T28, if its not for tears maybe you can justify the loss of 300 ish for a remap to the pay again to get the T28 mapped further down the road
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Id rather put the 300 towards the t28 i think
    Just got to find the correct version....
    hiltoa's Avatar
    VAG erfahren
    Jul 2006
    on the edge
    299
    Quote Originally Posted by Byzan A4 View Post
    Or maybe he has an N75J and doesn't realise it...
    If he's really lucky, he might find he has a 710N diverter valve too...
    Nothing feels fast for long...
    2004 Audi Allroad 2.5 TDI L.E.
    Ebony Black.
    1991 VW Golf GTI 16v
    Tornado rot.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Ahhh well ive removed the OE dump valve but its handy to know i have the other wotsit thingymagig whatever it is...
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,920
    My AEB only runs 12psi chipped Need more boost. Especially when the Americans on Audizine are running 18psi on naff fuel
    Life begins at 140mph
    www.passionford.com
    S4twiggy's Avatar
    Fully Certified Detailer!!
    Feb 2009
    South Wales
    1,811
    wot is the difference between the N75 and N75j?
    how can i tell wot boost my turbos are running at and wot would be the normal psi for the S4?
    lately i been thinkin my car is not running as she should be, its been quite flat feeling of late, id love to able to experience another S4 to compare wot it is like to mine, sometimes though the car pulls off like a rocket which is makin me wonder if something is not quite right with it.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Ive just been told you cant remap the B5s they have to be rechipped. Thats not right is it??
    S4twiggy's Avatar
    Feb 2009
    South Wales
    1,811
    how do i do a pressure test with a compressor?
    Apr 2004
    12,357
    Thats correct in this country, the us tuners somehow can flash them
    "Stick a V8 in it!"
    14,907
    Oranoco: Naff fuel? The yanks octane rating system is different to ours, so you need to add ~4-5 on to a yank number to compare with the UK's rating. Yankee 91 octane is just the same as 95 here, and "premium" gas in the states is usually 93 octane, which is the same as 97/98 here.
    I think the yank cars have different ECU's to ours, hence they're flashable.
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    i would like to put a t28 on mine but its the cost and hassle of getting it chipped thats stopping me.
  28. #27
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    So really we shouldnt say remap we should be saying chipped!
  29. #28
    Missed gear
    Jan 2006
    Kent
    385
    I thought the facelift B5's could be remapped though?
    Mine is a very early facelift so had to be chipped.
    B7 A4 Avant S-line Special Edition v2 2.0 TFSi - AmD stage 1 - 263Bhp 396Nm
  30. #29
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Quote Originally Posted by Stringster View Post
    Is youres standard other than the chip?
  31. #30
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,920
    I was not aware of this. Lesson learnt
    www.passionford.com
  32. #31
    Missed gear
    Jan 2006
    Kent
    385
    It was at the time of the chip. Still is really, just a few small upgrades.
  33. #32
    Jun 2009
    101
    Quote Originally Posted by Oranoco View Post
    Our fuel is measured by RON only.. American is (RON+MON)/2.. they call it 'octane' but it's not really.
    With regards to flashing ECU's.. I think the problem lies more to do with UK tuners not actually knowing how to do it more than the ECU's being different.. Any ECU since about 1990 will be 'flashable', somehow, it's just down to someone to figure it out..
    Everybody thought thought you couldn't re-program the Ford EEC-IV ECU until I designed a programmer for it.. (without an external chip module)
  34. #33
    "Stick a V8 in it!"
    14,907
    The ROM in the early AEB ECU's is NOT reprogrammable. Mappers have to remove the chip, burn the new map onto a NEW ROM and solder it back in.
    The biggest problem is that stocks of these early chips are becoming scarce.
    The later ECU's have a different ROM which isnt quite so rare, but afaik these also cant be erased, and need replaced.
  35. #34
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    Stock 1.8TQ hitting 14psi is not standard in any gear so something is different in his car for sure and it may well be chipped already.
    14psi to 15psi is the most you will get from a chipped K03 without a bleed valve so I would say the cars performing well with those figures.
  36. #35
    jcb
    Sep 2005
    uk
    4,070
    some do. some don't. the DBC ones are the same.
    I bought my replacement ECU from Tapp auto and it has the same code.
    They still chip them when required but there seem to be a lot more flashable later ECUs over there
  37. #36
    Jun 2009
    101
    Got the part number of the chip?
  38. #37
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Quote Originally Posted by docurley View Post
    If it is id hate to have driven it standard.
  39. #38
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    LOL
  40. #39
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Soooooooooooooooooooo slow
