help wrong turbo-K04 but with 5 bolt flange?
vagnutter
NULL
hey all, just new on here hope someone can help me out, i have an 00 A4 1.8T, the turbo is on its way out and i bought a new one problem is its a 5bolt flange pattern and not a three?
has any one any ideas what this turbo is for, and also where to get the right one in the UK.
this is the one i bought:
whats the code stamped on it and the compressor outlet look like (Alu bit)?
hey the code on the plate is just K04 then this serial:08016035
yea got it from ebay , the cars only for going to work and back so wasnt fussed... big mistake now, left with a nice paper weight.
any help is grateful
thanks
And that's all it will be, have heard a lot of people being sent the wrong turbo's and the ones that get the right ones just go bang very quickly.
I've also heard of success stories.
Theres a chap over on vauxsport that fitted an ebay special turbo to his C20LET and its been successfully producing big power figures:
"463 bhp @ 1.6 bar and 347 lb/ft
backed up with a
458 bhp @ 1.6 bar and 348 lb/ft
straight after"
He also managed to blow the welds on his intake manifold, which is quite funny.
Inlet crack:
http://i120.photobucket.com/albums/o199/turbogav/IMG_3492.jpg
Ebay Special next to a real T34:
http://i120.photobucket.com/albums/o199/turbogav/IMG_3120.jpg
Dunno if i'd want to risk wrecking a good engine with one, but afaik thats nailed onto a stock bottom end, so i guess its less of a worry.
How much you paid for it ? Thats not a KO4 but a 90 Bhp passat/audi a4 1.9Tdi turbocharger for the 90Bhp engine by the looks of it !
totally wrong then.
worked out £180 shipped. the company said they will take it back , but they are state side so is going to cost £40 to send.
Dam,
And it true I have also heard of good story's with ebay turbos, from what I can understand some of the ebay turbos are not ballanced or the waste gate is not fitted correctly due to bad casting which can be fixed with a bit of Dremerling.
....He also managed to blow the welds on his intake manifold, which is quite funny.....
Was he Granny Shifting not double-clutching like he should?
I need NOS 'cos my car topped out at 140 this morning...
Vagnutter, good luck in getting it all sorted out
Inlet crack:
mostly because he has tried to weld two different sized pipes and has not got enough penetration or a decent cap weld on a bend that is stressed as it is....
now this is a blown inlet mani! (scroll down)
1100kg Mk2 golf with 2.2 20v I5 S2 engine and chassis running GT35/40 with Nitrous!!
http://www.s2forum.com/forum/showthread.php?t=19402&page=20
ah well spotted, editted now
I was wondering the same. My engine code is BFB 1.8t what's the part number of the k04 turbo upgrade that I need to get. On seller asked my if I had a five bolt design which I have no clue of. Do I use five or three? Thanks!
993
841
11
2K
jcb
