EM TuningVolks Autos
    Fraser's Avatar
    Aug 2003
    the north
    586
    Instrument Cluster Bulbs change - with pics
    finally decided to get round to pulling out the instrument cluster to change the bulbs that had gone on my 1996 A4 T Sport
    tools needed
    1x thin nose pliers
    flexible philips heand screw driver (socket set type is fine)
    6mm socket for the bulb removal and refit
    use this guide to help remove the cluster - the 3 plugs are a bit awkward due to the small space you have, just turn the instrument panel to gain access.
    http://www.audiworld.com/tech/int43.shtml
    I have taken some pics to show the back of the cluster
    there are the following number of bulbs
    10x Orange 1.1w bulbs
    1x Green 2w bulb
    7x black 1.2w bulbs
    there are also a number of blanks in my car - 5 on the right looking at the back of the cluster, 2 on the left.
    front
    back
    bulbs
    Crombie's Avatar
    Apr 2009
    Preston
    56
    One of mine @ top of speedo has its on n arf days. cheers for info, its on list of ta-do's.
    Fraser's Avatar
    Aug 2003
    the north
    586
    just anote to say i have replaced all the black bulbs with the orange ones no problems
    the stealer was not able to order the black ones
