Chris NottAH Fabrications
    codrock's Avatar
    Nov 2008
    49
    how to turn off service light on audi a4 2000
    had service done just need to turn the word service! off of the speedo panel
    its a year 2000 audi a4 tdi
    any help please
    Jun 2003
    World of my own
    9,813
    IIRC this only works on facelift models 99 on so should be OK on your 2000, I know it doesn't work on my 97 A4 which has to be done via VAGCOM:
    1. Insert your key into the ignition.
    2. Push in the odometer reset button, hold it in, and turn the key to the first click.
    3. The display should read either "oil" or "service" if it does not, repeat steps #1 and #2.
    4. To reset, pull out your instrument light dimmer button at the bottom of the tachometer.
    5. Turn the ignition to the off position. When the ignition is turned back on, the display should be back to the trip odometer.
    Alex Turner
    Cruz's Avatar
    Apr 2009
    74
    Does this work for inspection aswell?
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    my facelift b5 had to be done on vagcom.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    i managed to clear mine 2000 year b5 with a method similar to AndyMac
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Jun 2003
    World of my own
    9,813
    Can't verify the above as working, but reliably informed it is the correct sequence for facelift B5's. Similar procedure worked a treat on our B6, which was from the same source. You can obviously do it via VAGCOM on any vehicle.
    Alex Turner
