Badger5EM Tuning
Results 1 to 8 of 8
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    (P) Light contantly on? Faulty handbrake switch?
    Along with the constantly flashing heaterplug light (light out on the rear window brakelight), I now have the red (P) light on in the dash, is it the handbrake light?
    Jonny
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    i dont get what you mean about it not coming on when its off?
    If its on all the time then i'd imagine its a faulty switch or wiring.
    TD5 Land Rover Defender build
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Lol,
    Cheers for the reply, I mean that when I pull the handbrake on, no light appears in the dash to say its on. The (P) light just randomly appears and dissapears throughout the journey.
    J
    1996 A4 B5
    1.9TDI SE
    "Stick a V8 in it!"
    15,388
    sounds like a switch or wiring problem then...
    You sure its (P) and not (!), (!) generally indicates the fluid level.
    If it IS the fluid level, dont just top it up. If its low it means its either leaking, or that the pads are very worn
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Yeah, double checked definately a (P), fault is intermittent as well, car drives normally too, and all the pads are fine, brake fluid level is the only other thing I have to check.
    On another Audi does a light come on with the handbrake up?
    JC
    1996 A4 B5
    1.9TDI SE
    inS4ne's Avatar
    lives for speed
    Jun 2009
    96
    Hi Jonnycraig,
    The parking brake light should illuminate on any car when the brake is engaged.
    As already has been suggested, if the light is intermittant, it would suggest a wiring fault or connection somewhere. I would start by checking both ends of the circuit first (connection at parking brake end and behind the instrument cluster).
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Update
    Driving home along the motorway last night, noticed the (P) light was flickering on and off now and again, then came on solid for a while then off completely, so will try and replace the switch if I can figure out how to remove the centre trim by the handbrake.
    Checks I did, brake fluid reservoir is actually too full (any suggestions) and is this bad?
    Could probably do with new rear pads and discs to be perfectly honest, they are working but they are mega rusty eww!! lol
    Jonny
    1996 A4 B5
    1.9TDI SE
    "Stick a V8 in it!"
    15,388
    Ours is too full too, common side effect from using a pressure bleeder and doesnt really matter too much. Just need to be careful when replaceing pads as pushing the pistons back will push fluid back up into the resovoir. Something to suck the excess fluid out the bottle would be useful.
