Sky InsuranceChris Nott
Results 1 to 8 of 8
    Jul 2006
    1,562
    RS4 Vs S4 suspension?
    How different were the RS4 shocks and springs compared to those on the S4 (poundage/design/ride-height etc etc)?
    Jun 2009
    102
    Are you considering using them on your S4? Do you know if the package will physically fit? From what i've read, the RS4 has different front knuckles so may use a different damper design.
    Either way, to answer your question.. Dampers and springs are specially designed for every car.. as soon as you change it, or put it on something else, it will technically be 'wrong'.. Eg, the unsprung weight will most likely change, affecting the wheel frequency, which ultimately means the damp/rebound/spring shock absorber package won't be as good as it could be..
    Jul 2006
    1,562
    There are plenty of S4's running RS4 suspension without issue lol
    All academic now anyway as I got pickled in the garden and clean forgot about the end of the Ebay auction
    Hampshire
    102
    Not recommended anyway unless your existing S4 suspension is broken/very tired and
    you can get the RS4 setup for a song.
    MY2000 Audi S4
    Ebony Pearl
    CXRacing FMIC
    RS4 Downpipes
    RS4 brakes
    Miltek Dual
    Vogtland CO
    K04's
    Lowered CR & MRC Magic......
    (RS4 ICs 4 sale - check classifed)
    jcb
    Sep 2005
    uk
    4,077
    most decent coilover from aftermarket suppliers list one fitment for S4/RS4.
    KW certainly do.
    I would be wary of buying any used shocks if that is what you are thinking.
    I sold my quattro sport shocks and springs for 25! noone wanted them
    Oct 2007
    2,597
    ^^^ Agreed.
    I'd never install used dampers, springs, probably.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,299
    I fitted craigs old S4 dampers to the front of ours.
    I figured 85k old S4 dampers would be better than 175k 1.8T dampers (yep they were the originals!), and seen as i had it all apart it made sense to simply drop them in.
    TD5 Land Rover Defender build
    Jul 2006
    1,562
    Yeah fair comment, and I would never ususally consider fitting used suspension, but this kit has supposedly done 30K miles as opposed to my tired 97K S4 originals.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=330338536643
    Furthermore, a grand for a good set of coiloers just seems too rediculous for a 10 year old car.
